Lionheart7004 Neutral Newbie June 15, 2005 Share June 15, 2005 As a gadget man, can start to pick it up now. BTW, putting the cap at the trunk is okay, so no need to shift. However, i would like what type of cable to use for the trunking between Bat & Cap? Thick power cable. ↡ Advertisement Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 15, 2005 Author Share June 15, 2005 Currently am using 8awg shielded cable.. Link to post Share on other sites More sharing options...
York Clutched June 15, 2005 Share June 15, 2005 ventilation fan blowing on the device inside the trunk...dun think it'll be effective...as it'll ciculation the hot air... maybe cut a hole, install a vent fan to draw out the hot-air will be more effective. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 15, 2005 Author Share June 15, 2005 I do find that the 'fan' can be noisy.... Vent fan.... I wonder where I can found those small enough for cars... You have any idea? Link to post Share on other sites More sharing options...
Ivan0507 Neutral Newbie June 15, 2005 Share June 15, 2005 bro , make sure yr power wire from amp to yr capacitor as short as possible about 12"( 1 ft) will be good ,don't put yr cap at engine compartment ,damage yr cap. Link to post Share on other sites More sharing options...
York Clutched June 16, 2005 Share June 16, 2005 (edited) So any noticable improvements after installing the capacitor??? tis articles may clear ur doubt on power capacitor; http://www.carstereopro.com/technical/capacitors.htm Edited June 16, 2005 by York Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 16, 2005 Author Share June 16, 2005 Thanks... it is about 1 ft. Link to post Share on other sites More sharing options...
Ivan0507 Neutral Newbie June 16, 2005 Share June 16, 2005 yes.about 1 ft Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie June 16, 2005 Share June 16, 2005 Actually does a capacitor really work? Is it necessary? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 16, 2005 Author Share June 16, 2005 some says yes, some says no... i went ahead and fixed it... my voltage are more stable. Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie June 17, 2005 Share June 17, 2005 Voltage is theoretical lah, but do you hear any difference? I was told that the capacitor "robs" the amplifier of power. Is that true? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 17, 2005 Author Share June 17, 2005 I'm more concern about my voltage dropping. With the additional cap, am not seeing such things.. Link to post Share on other sites More sharing options...
Wankie Clutched June 17, 2005 Share June 17, 2005 platform OT... eh taukeh, when's the next BKT session? Arrange leh Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie June 17, 2005 Share June 17, 2005 Oh wait, you're concerned about the voltage dropping, affecting the sound system or other parts of the car? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 17, 2005 Author Share June 17, 2005 John, In short, whenever I blast my music my voltage drops and with the cap, seems like my issue have been resolved. Link to post Share on other sites More sharing options...
York Clutched June 17, 2005 Share June 17, 2005 (edited) there 'll be different when u used 2 to 3...more then 400W> amp to drive ur spkrs + sub -woofer...even @ engine idling..ur sub-woofer wun go 'Blah blah blah'...rumbling... For me, I changed to a higher capacity alternator + bigger battery to cope wif the current demand... Edited June 17, 2005 by York Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 17, 2005 Author Share June 17, 2005 I might be looking at another bigger alternator.. But then again, am only driving my car for another 1 year 9 months... Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie June 17, 2005 Share June 17, 2005 Erm ya, I know. What I meant was "so what if voltage drops"? Does it harm the car? Does engine become v rough? ↡ Advertisement Link to post Share on other sites More sharing options...
Mazda 3 BM capacitor change...
Home power back up
Home power back up
Honda Stream 2009 No Power and High fuel Consumption
Alcades power optimizer
Microsoft to buy solar power in Singapore
Cordless power tool system - which one ?
Not all heroes wear capes! Liverpool taxi driver prevents terrorist attack!
