Law_ong Neutral Newbie June 17, 2005 Share June 17, 2005 ya..to store the required amount of current required for the amps... ↡ Advertisement Link to post Share on other sites More sharing options...
York Clutched June 17, 2005 Share June 17, 2005 Bro, I got a ques here. I was wondering if I off my engine but the system still on does the system run on the capacitor's electrical energy first or still from the car battery ? still frm the battery.....ur sub-woofer will function normally due to the capacitor 'boost'...if no capacitor....within sometimes...the sub will not function properly...it's the sub amp that drained the most current.. Link to post Share on other sites More sharing options...
Xiaogary Neutral Newbie June 18, 2005 Share June 18, 2005 Interesting. So how will be the connection of the capacitor like? I saw that mine cadence 4 X 75w amplifier has a port to connect to capacitor. Do I connect from there? Or connect at the battery straight away. My monoblock amp doesnt have any connection for capacitor, duno why. Mine monoblock amp is driving my 12 inch sub at 350w rms and 1300w max. Mine 4 channel amp is powering a front component and rear 6X9 speaker at 75w rms per channel, the peak power for the 4 channel amp is 800w. I think even if I on my volume to max, the peak power will only be 350w rms for monoblock amp and 300w rms from 4 channel amp right? Total only 650w rms. Or should it be 1300w+800w = 2100w. I think I read from some web site, 1 farad for every 1000w system, if 2000w need 2 farad. But I never remember it states rms or peak? Now I am thinking whether I need a 1 farad or 2 farad capacitor. The price difference is quite great. $180 for a cadence red 1 farad with voltmeter reading and $300+ for a 2 farad one (rectangle one). Link to post Share on other sites More sharing options...
Seaweed 1st Gear June 20, 2005 Share June 20, 2005 hey bro...check with you har...you know how to dismantle head unit from car ?? think all car should be roughly the same right...i driving a sunny....think of installing a woofer on my own... Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 20, 2005 Author Share June 20, 2005 Yes and no... there is this plastic cover for the HU. Normally that's the most difficult part to remove. Once you are able to remove that, I should be able to help with the rest. Link to post Share on other sites More sharing options...
Seaweed 1st Gear June 20, 2005 Share June 20, 2005 you know how usually is all this cover tighten ?? by clips or but nuts ?? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 20, 2005 Author Share June 20, 2005 the plastic is by clips. at times, you need some special tools to remove.. For example, we have a hard time trying to remove the stock HU for aveo the last time.. Link to post Share on other sites More sharing options...
Seaweed 1st Gear June 20, 2005 Share June 20, 2005 think must go radio shop squat there see see liao... Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 20, 2005 Author Share June 20, 2005 unless you are willing to take risk to DIY.. Link to post Share on other sites More sharing options...
Ivan0507 Neutral Newbie June 20, 2005 Share June 20, 2005 bro,normally head unit will come with 2 metal piece,like a keys.just slot in both side of the head unit and pull it out ,before pull it out .check the top and bottom of the head unit to see any metal clip holding the head unit ,if not just pull out the unit. Link to post Share on other sites More sharing options...
Xiaogary Neutral Newbie June 22, 2005 Share June 22, 2005 If anyone need to remove HU for aveo or speaker or door panel, I can help u, bcos I did mine a few time. Initially also very difficult and scary, scare will break it. Link to post Share on other sites More sharing options...
Firefighter Neutral Newbie August 23, 2005 Share August 23, 2005 I planning to install my 2 component speaker and subwoofer powered by 4chan and 2chan amp. The above setup need a cap? cause my new car have lousy maint free batt. Link to post Share on other sites More sharing options...
Reymund Neutral Newbie August 23, 2005 Share August 23, 2005 Are u driving a N16???.........If yes, shld be fairly easy......on the top there is this compartment with a lid..... 1) Open up the lid and pull outwards towards you..it shld come off easily 2) Then it shld reveal 2 screws.....unscrew them 3) then open the ash tray area.......take out the ash tray....there also reveal 2 or 4 screws....... 4) Check any other screws securing the front instrument panel......just to double confirm...... 5) once the whole front panel is removed.......you shld be able to unscrew ur HU from which have screws securing the HU to the side metal frame..... I've sold off my N16 1y+ back liao......hope I still can remember the screws and stuff......but its not difficult at all......hope it helps......otherwise, can call me if u live in the west so I can pop by to help u......I DIY my last ride also.....If ur previous installer lazy to dismantle the front panel.....then its even easier.....just use the tool that comes together with ur HU.....slot into both sides of the HU and pull them out.....but N16 seldom installer do that....I forgot the exact reason liao....Enjoy ur DIY Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear August 24, 2005 Author Share August 24, 2005 (edited) the reason I installed the P.C cos there was a drop on power whenever I blast my music. After the installation, my voltage seems to be be more stable. p.s: I have a similar setup.. Edited August 24, 2005 by Gadgeter Link to post Share on other sites More sharing options...
Firefighter Neutral Newbie August 24, 2005 Share August 24, 2005 So i think mine will have same problem. NVM will see if my light will blink when all is on? Thanks! Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear August 24, 2005 Author Share August 24, 2005 welcome. If you fae the same problem, do let me know.. P.S: 1.2 Faraz is good enough. Link to post Share on other sites More sharing options...
Superblackbox Neutral Newbie August 24, 2005 Share August 24, 2005 hmmm learn something more from here.... real infomative site.. for newbies like me to learn but also kenna posion.... Link to post Share on other sites More sharing options...
Headshok 1st Gear August 24, 2005 Share August 24, 2005 part of y the power drop (ie ur lights start to blink is cos of the installation of the ICE>... factors like grounding and circuit breakers.. power capacitor also help to give power to the amps..but sometimes when ur amp sucks like hell.. still can see the drop in power.. my 2 amps power hungry man. ↡ Advertisement Link to post Share on other sites More sharing options...
Carbonics Cold Air Intake System - Full Handmake CF
Mazda 3 BM capacitor change...
Home power back up
Home power back up
Honda Stream 2009 No Power and High fuel Consumption
Alcades power optimizer
Microsoft to buy solar power in Singapore
Cordless power tool system - which one ?
