Genie47 1st Gear June 14, 2005 Share June 14, 2005 Been doing some thinking. I have this hunch your FC is indeed tied to your choice of spark plugs. Specifically the heat range. If you are the urban type driver, more jams, more congestion, more stop-start than usual. Hotter plugs should be used. 16 range (Japanese) or 5 range (Euro) should be used. If you are more of the highway cruiser, then colder plugs are better. 20 range (Japanese) or 6 range (Euro). Anyone out there got some arguments to destroy this hypothesis? ↡ Advertisement Link to post Share on other sites More sharing options...
Trex101 3rd Gear June 15, 2005 Share June 15, 2005 Well my plugs are burning much much cleaner when using hotter 5 plugs than heat range 6 plugs even though my manual states my stock plugs as NGK BKR6E-11 Link to post Share on other sites More sharing options...
Westwind Neutral Newbie June 15, 2005 Share June 15, 2005 If I remember correctly, spark plugs also serve to dissipate heat from the engine. Colder plug dissipates heat faster. Hence a colder plug is often used in an engine with higher compression or car which travels long distance frequently. You are right to use hotter plug for short distance or city driving. It reaches its optimal or self cleaning temperature earlier/faster. Engine using hotter plug has a shorter warm up time in the morning from what I observed. Link to post Share on other sites More sharing options...
Vtim 3rd Gear June 17, 2005 Share June 17, 2005 actually, the engine is already design to use certain heat range of plugs so, FC should be only depend on your driving pattern. As for me, it's my HRF that controls the FC NGK 5 is equal to Denso 16, both are Japs ley Link to post Share on other sites More sharing options...
Orixy 2nd Gear May 21, 2007 Share May 21, 2007 Hehe... found this interesting discussion when I was searching for some info on effects of using a hotter plug. Like to ask the gurus: >> The use of a hotter plugs (NGK 5[hot] vs 6[cold]) is better for city driving. But is this true only for stock cars with no mod? For example, adding a piggyback ECU to advance the ignition timing is a common mod to gain power, but advancing ignition timing also increases engine combustion heat - as indicated in NGK's webby : http://www.ngksparkplugs.com/tech_support/...ng.asp?mode=nml So in this case, a hotter plug is not recommended when a ignition is advanced even though it is better for daily city driving? >> Also heard of some ppl purposely using plugs with a longer tip (eg. plugs meant for some Hondas are known to have a longer tip) so that the combustion can be more complete due to fact that the tip is sitting "deeper" in the cylinder. Is this true? Link to post Share on other sites More sharing options...
Genie47 1st Gear May 21, 2007 Author Share May 21, 2007 Heat range of the plug is dependant on many factors. All of them mentioned in your post affect the selection. Rich fueling, ignition advance, type of fuel. Stick with the manual. Link to post Share on other sites More sharing options...
Dwoon 1st Gear May 21, 2007 Share May 21, 2007 I've used heatrange 6 & 7.... like no diff leh.... Now gonna try 8. Got a set of NGK R7119-8 for sale and I'm gonna try them out. Hope they don't cause any issues. BTW, between platinium & Iridium, which is actually better? Because the R7119-8 are Platinums and they actually cost so much more than the Iridiums when I did a search. Both are fine tip. Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie May 21, 2007 Share May 21, 2007 (edited) hmm.. tried both 16 & 20, the difference is there, but minimal, i get slightly better FC for 16 when driving in singapore. in .my, its WOT most of the time 20 plugs aren't as "white" as "16" when i take them out for visual inspection. hmm.. but cng burns hotter right? but is it hot enough to need a cooler plug? Edited May 21, 2007 by Cyberet Link to post Share on other sites More sharing options...
Orixy 2nd Gear May 21, 2007 Share May 21, 2007 Got a spare set of 5 heat range NGK gpower plat so tot of using them but my engine is speced to run on 6... Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie May 21, 2007 Share May 21, 2007 (edited) my engine is one that requires a "extended" tip spark. KJ16CR-L11 Iridium equal is IK16L http://www.globaldenso.com/PLUG/config/index3.html http://www.globaldenso.com/PLUG/search/zip/singapore_4w.zip Edited May 21, 2007 by Cyberet Link to post Share on other sites More sharing options...
Orixy 2nd Gear May 21, 2007 Share May 21, 2007 hehe... wont try this risk of cos!! :) Link to post Share on other sites More sharing options...
Genie47 1st Gear May 21, 2007 Author Share May 21, 2007 Yes, Pt tips cost hell a lot more actually. Go for Pt if they are cheaper than Ir. An expensive Ir tip plug means the seller is trying to fleece you. If there is no difference to you, that means your car has not gone through enough mods that demand a heat range change. Link to post Share on other sites More sharing options...
Genie47 1st Gear May 21, 2007 Author Share May 21, 2007 CNG indeeds burns a lot hotter and drier. Actually I kept my plug's heat range the same as the petrol so to clean it off better. I'm running dual fuel actually so it makes no sense to go colder yet unless I fit in an MSD coil. Anyway, the fueling is already programmed and optimized on these stock copper plugs. Link to post Share on other sites More sharing options...
Genie47 1st Gear May 21, 2007 Author Share May 21, 2007 You can try them out. The main problem you will experience is predetonation. Hot plug tip = glowing hot matchstick head to explode the fuel/air mix. Link to post Share on other sites More sharing options...
Fitzy Neutral Newbie May 21, 2007 Share May 21, 2007 My manual say to use heat range 5, what if i use heat range 6, will i encounter any prob? Link to post Share on other sites More sharing options...
Genie47 1st Gear May 21, 2007 Author Share May 21, 2007 (edited) Your plugs will be colder so there will be fouling. The heat range makes the plug attain a certain temperature that allows it to be hot enough to burn of carbon (self cleaning) and yet prevent detonation from being too hot. Explains why some cars don't like Bosch Super 4 or some multiground plug. They have more metal (more than 1 leg) and these things actually retain heat. Edited May 21, 2007 by Genie47 Link to post Share on other sites More sharing options...
Fitzy Neutral Newbie May 21, 2007 Share May 21, 2007 (edited) I'm driving Altis and planning to change to NGK iridium BKR6EIX-11. Currently on stock BKR5EYA-11. Some ppl say BKR5EIX-11 too hot for altis but at the NGK website, the cross referece guide showed BKR5EIX-11 the right plug. I'm confuse if i should stick to 5 or 6. Edited May 21, 2007 by Fitzy Link to post Share on other sites More sharing options...
Dwoon 1st Gear May 21, 2007 Share May 21, 2007 Yes, Pt tips cost hell a lot more actually. Go for Pt if they are cheaper than Ir. An expensive Ir tip plug means the seller is trying to fleece you. If there is no difference to you, that means your car has not gone through enough mods that demand a heat range change. Guess for a set at SGD60 which is being hogged off.... I'll just get them and try out. (online websearch shows they cost like US$35 a piece. ) So far, all my plugs (6 & 7) have come out at 25K km... they don't show any carbon fouling but neither are they white.... so dunno if the heatrange I'm using is correct. ↡ Advertisement Link to post Share on other sites More sharing options...
EV Tyres
EV Tyres
Range Rover Evoque
Range Rover Evoque
Tool to change Spark Plug
How Much Range Does an Electric Car Lose Each Year?
Energy Savings / Non Heat up LED Headlights Technology
Changing of Spark Plugs
So is MSG good or bad for health?
S'pore could hit 40°C by 2045, but has measures in place to tackle rising heat
