Kelkel Neutral Newbie July 12, 2005 Share July 12, 2005 hi again..juz checking if this oil is good??? ↡ Advertisement Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear July 12, 2005 Share July 12, 2005 Hi, I have been using this oil for close to 2 years. So far so good. Link to post Share on other sites More sharing options...
Kelkel Neutral Newbie July 12, 2005 Author Share July 12, 2005 whatz the oil diff from the mobil 0W 40???whatz your ride btw??? Link to post Share on other sites More sharing options...
Genie47 1st Gear July 12, 2005 Share July 12, 2005 (edited) A scale thicker than your usual oil. You must understand. Higher viscosity oil does not protect better or have better performance. The main purpose of thick 50wt oil is to combat fuel dilution of oil due to rich mixtures. If you car is new as in less than 10yrs old, 30wt oil is sufficient. 40wt is a little thicker but the only cars sanctioning the use of 40wt oil are the Conti cars with VW or MB engines. When oil is thinner, there is less friction. Less friction means less drag on the engine components which means slightly more "power released". Also means less heat so engines run cooler. Edited July 12, 2005 by Genie47 Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 12, 2005 Share July 12, 2005 That's pretty thick viscosity, how old is your car and what is your current mileage? 15W50 for a track day will definitely be recommended Link to post Share on other sites More sharing options...
Chinkeong Neutral Newbie July 13, 2005 Share July 13, 2005 think 0W 40 lower viscosity may cause more engine noise but may improve the Fuel consumption.... personal opinion ↡ Advertisement Link to post Share on other sites More sharing options...
To be Happy, start thinking about Death!
I tried Sliplo and here's what I think.
So you really think you are BIG...
Bringing a nice & new luggage bag to China...think again
Monkey think, another monkey do
Aston Martin DB11, what do you guys think?
If you think the RGS bullying is bad, see this
