Phantom105 Neutral Newbie August 5, 2005 Share August 5, 2005 Thanks for your advise I'll take note of that ↡ Advertisement Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 5, 2005 Share August 5, 2005 (edited) No problem Bro, jus sharing my limited knowledge One more is the type of engine oil For newer cars, use those engine oils ending with 30s or 40s, avoid using those 50s one IMHO Once a while, pour some injector cleaners (Certain brands can be bought off shelf from petrol stations) onto our fuel tank to clean our injectors, this would also help a bit Edited August 5, 2005 by Mzrmazda3 Link to post Share on other sites More sharing options...
Serene Neutral Newbie August 5, 2005 Share August 5, 2005 hi, how often do you pump your tyres? Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 5, 2005 Share August 5, 2005 (edited) Hi Serene , i pump my tyres every week when i re-fill petrol A bit kiasu Edited August 5, 2005 by Mzrmazda3 Link to post Share on other sites More sharing options...
Phantom105 Neutral Newbie August 5, 2005 Share August 5, 2005 The last servicing I went the mechanic intro me the Prestone syn engine oil...after a while I feel that its not smooth...maybe is the wrong type of oil used. I'm thinking of changing a better spark plug + air filter + castrol engine oil. Do you think it will help with better mileage? I did use some petrol treatment and indeed improve a little[drivingcar] Link to post Share on other sites More sharing options...
Serene Neutral Newbie August 5, 2005 Share August 5, 2005 actually i wanted to do it this way too but my bf say me ... cos i find that my FC very good everytime i pump mu tyres to the fullest.. ok i will do it this way too.. thanks Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 5, 2005 Share August 5, 2005 (edited) IMHO, better spark plugs i.e Iridium plugs would give you a smoother ride whether when your car is idling or when you 'Ta You' Air filter also plays a part too cos when your air filter is dirty, you'll feel that your car is 'Bo Luk' hence you'll 'Ta You' more For air filter, some people change to aftermarket types i.e K&N, Simota ... etc Castrol is a good oil IMHO expecially the RS series There are a few threads on engine oil in this forum, you might wanna check it out especially from Bro Genie whom is a oil guru (Bro Genie, don't mind if i quote you ) Edited August 5, 2005 by Mzrmazda3 Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 5, 2005 Share August 5, 2005 No problem If we pump it weekly at least we can get to monitor whether our tyre got 'Lau Hong' or not Link to post Share on other sites More sharing options...
Serene Neutral Newbie August 5, 2005 Share August 5, 2005 ya.. true Link to post Share on other sites More sharing options...
Osiris 1st Gear August 5, 2005 Share August 5, 2005 wah! Everyweek your tyres lao hong? I check every week but usually no need to pump till 4 weeks. Link to post Share on other sites More sharing options...
Serene Neutral Newbie August 5, 2005 Share August 5, 2005 must drop by how much den consider 'lau hong'? Link to post Share on other sites More sharing options...
Phantom105 Neutral Newbie August 5, 2005 Share August 5, 2005 thanks for all tis advises bro... will feedback u after I get all tis things done Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 5, 2005 Share August 5, 2005 Bo lah Until now haven't lau hong yet Jus become part of my habit since i started riding Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 5, 2005 Share August 5, 2005 No problem For engine oil, you might wanna try out Amsoil or seek Bro Genie's advice Link to post Share on other sites More sharing options...
Osiris 1st Gear August 5, 2005 Share August 5, 2005 Oh, so you just squeeze in a bit of more air everytime to maintain correct pressure. Link to post Share on other sites More sharing options...
Phantom105 Neutral Newbie August 5, 2005 Share August 5, 2005 okie bro...will chk that out Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 5, 2005 Share August 5, 2005 For this, i feel that if we pump regularly say 5-7 days interval the pumping air sound from the air pump machine shouldn't be more than 3 times (For my case, only 1-2 times max or sometime none using SPC's digital pump) If the sound last for 5-7 times then must take note liao for that particular tyre but must be sure that you are pumping in the same psi as before Above are jus my experience so mai flame me if not accurate Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 5, 2005 Share August 5, 2005 Normally, jus pump back the same psi setting so i guess that there shouldn't be any extra air tio bo? ↡ Advertisement Link to post Share on other sites More sharing options...
Citroen C4 1.2 Sensor & Display
MyResponder app to call SCDF
