Jive Neutral Newbie April 26, 2007 Share April 26, 2007 When throttle body is dirty, whats the cause of it? If i dun clean or repair, which cost $300 over dollars, what will happen? ↡ Advertisement Link to post Share on other sites More sharing options...
Followthelaw Neutral Newbie April 26, 2007 Share April 26, 2007 (edited) Wau lau,what car u driving???????????Clean n service TB need 300 bucks ah.Whatever u driving,a mechanic told me at most cost rm90 to totally clean and service TB. Some more do it in front o u. If u dun do anything,car will die off,must be careful with your accelerator,if manual. But if auto,I dun know how lor. Cause the TB is highly sensitive,too thick dust coating sure engine will die,esp when cming to a stop.............. Edited April 26, 2007 by Followthelaw Link to post Share on other sites More sharing options...
Route88 2nd Gear April 26, 2007 Share April 26, 2007 Actually you can DIY, cost less than $10 Link to post Share on other sites More sharing options...
Lorrliew Neutral Newbie April 26, 2007 Share April 26, 2007 (edited) If I remember correctly, my machanic at AMK auto point charge me $80. Some cars has throttle body sensor attached to it, then the sensor will go haywire, car kado kado and dies off. Engine check light also comes on. Edited April 26, 2007 by Lorrliew Link to post Share on other sites More sharing options...
Followthelaw Neutral Newbie April 26, 2007 Share April 26, 2007 I knew this mech at JB,the fellow does high end cars like alfa romeo,bmw etc......... TB is chicken feet to him. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear April 28, 2007 Share April 28, 2007 The mech is trying to chop you!!! Go to someone else! Link to post Share on other sites More sharing options...
Jive Neutral Newbie May 3, 2007 Author Share May 3, 2007 C&C charge me $343 and of course i didnt want to. So far l've been driving my car for a week and seems normal to me. Well, i did remove my KNN air filter to normal paper one. So any way to DIY clean the TB? Where the hell is this TB??? Link to post Share on other sites More sharing options...
Route88 2nd Gear May 3, 2007 Share May 3, 2007 $343 is changing the whole TB right? Link to post Share on other sites More sharing options...
Ivanp Neutral Newbie May 3, 2007 Share May 3, 2007 Cleaned my TB for $65 at SinMing. Prior to that, my ride was giving me some problems like dying at traffic lights Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear May 3, 2007 Share May 3, 2007 You should be able to find "throttle body cleaner" or carby cleaners from most auto accesory places. If you can't find it, go to subaru's dealer. they're sure to have it as its part of their maintainence as req from subaru japan. Link to post Share on other sites More sharing options...
Imamiah Clutched May 3, 2007 Share May 3, 2007 bro, u happen to be driving the old lancer GDI? tt car's TB got prob.. tt's y i let go of it instead of cleaning it or replacing it. Link to post Share on other sites More sharing options...
Kb27 Supersonic May 4, 2007 Share May 4, 2007 You can diy to clean the TB. Just follow the air intake hose back to the engine area. The metallic body where it join up is the TB. Depending on what type of car you drive, outside the TB you can see a cable which is the accelerator cable. On the TB, there should be a electrical connector which is normally connector to the Throttle Positioning Sensor. On the hose, there should be some kind of hose ring/clip, remove it and pull out the hose and you should see the TB air intake and a butterfly flap. With the engine off, you can push down the spring loaded flap and open it. Just clean around that area with kerosene and microfibre cloth. Link to post Share on other sites More sharing options...
Robin 4th Gear May 4, 2007 Share May 4, 2007 i DIY clean it every 20k - 40km. quite a bit of carbon inside. i just clean the TB .. i never touch the MAF though Link to post Share on other sites More sharing options...
Jive Neutral Newbie May 4, 2007 Author Share May 4, 2007 $343 is changing the whole TB right? Read my lips... REPAIR. Link to post Share on other sites More sharing options...
Route88 2nd Gear May 4, 2007 Share May 4, 2007 Eh...WHERE's ur lip Its either change or service,how to repair,if the butterfly valve is spoilt means it spoilt,(if u know wat i'm talking about). I dont think agent do repair Link to post Share on other sites More sharing options...
Des8080 Neutral Newbie March 31, 2011 Share March 31, 2011 Recently i hav replace a throttle body sensor for my honda fit, after resetting, the engine check light still on and cannot accelerate. Can help pls? Link to post Share on other sites More sharing options...
Kb27 Supersonic March 31, 2011 Share March 31, 2011 Recently i hav replace a throttle body sensor for my honda fit, after resetting, the engine check light still on and cannot accelerate. Can help pls? Is your FIT using MAF or MAP sensor ? If you replaced the sensor on the TB, then it's probably a MAP sensor. Shouldn't the workshop who replaced for you fixed the problem? If you had DIY, you can try to put back the old sensor, and checked the wirings/connectors are properly fixed back. You would also need a OBDII reader to check what code the CEL light is for. Most likely, it's for the sensor that you or the workshop touched. Link to post Share on other sites More sharing options...
Des8080 Neutral Newbie March 31, 2011 Share March 31, 2011 Now the problem is the mechanic had cleared the fault but during test drive the problem occure again. Is there somewhere latch fault haven clear? ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
Home repair advice needed
