Ultra Racing Strut Bar Review
Satria_neo
given the choice, should go for front or back under brace?
Definitely the front. Your engine causes lots of chassis flex (due to shifting of weight as you turn).
I had struts and underbraces in my previous car (mazda 3) too.
In my opinion and experience, it's better to install the full set of braces if you intend to.
This is because just strengthening one end of your car may put stress on the other parts of your chassis, all else being equal.
Most decent cars chassis and suspension has been carefully calibrated and stress tested from the factory, so just beware of the balance when you tune.
Cheers!
Cheers!
Maybe just to add on what I meant.
If you just strengthen one end of your car, sooner or later you are definitely going to find that the other end is lacking.
hmm.. most of the car has front ARB.. unless u want swap for a bigger front ARB...
just start with rear ARB... rear boot strut bar if applicable...front strut also... not enough...add on coilover ..open rear/front -ve camber...up size rim / uhp tire / not enough... front RCA!! and back also if applicable... [laugh]
not enough... spot welding... not enough??? change to fd2r... good car to start off with... [laugh]
I've ever seen a Honda Stream with UR Strut Bar when hoist up, the front undercarriage bar was deform as the car apparently had hit something on the road..
As i sometimes park half the car off the road and sometimes travel in Malaysia "B" type of road.. i stayed away from all this bars.. But i have a front tower strut bar installed.. Good handling round corners though..
Does it use two or one bolt connection for under the hood strut brace? It looks like one bolt which would be quite the strain on that single bolt on each side.
UR front strut bar uses single bolt connection at each end...agree that can caused great strain...so use Alutec..
I used
1)Alutec front upper strut bar
2)UR front 3 point lower brace
3)UR rear 2 point brace
4)UR rear ARB
5)Summit rear bumper bar
So far so good for the pass 4yrs and no deform ... [cool]
ultra racing strut use thin and weak material. don't waste your money on it.
Steel is much stronger than aluminum, but heavier. Racing cars usually use chrome moly steel bars at the expense of weight due to its strength.
Dont think all these bars help much on high speed.
Helps in adding weight. Lol
