Darganz Neutral Newbie August 2, 2005 Share August 2, 2005 Hi, I just discovered that the a piece of the "ring" surrounding the base of the antenna of my Skoda Oct has broken...anyone noes where to get replacement for such thing? Tks! ↡ Advertisement Link to post Share on other sites More sharing options...
Steady Neutral Newbie August 2, 2005 Share August 2, 2005 U can check with Lightspeed, believe he just changed his because of "cracking" antenna. Think he bought from Xin Zhong. Or you might want to try those short antenna replacements, try searching the forum. Good luck. Link to post Share on other sites More sharing options...
Lightspeed Clutched August 2, 2005 Share August 2, 2005 Mine was the antenna itself... not the base leh Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie August 2, 2005 Share August 2, 2005 If the antenna is broke, how to replace it? I can't seem to remove the antenna... Keep screwing and screwing and screwing somemore... Antenna doesn't want to come off... Link to post Share on other sites More sharing options...
Lightspeed Clutched August 2, 2005 Share August 2, 2005 Mine came off easily... hmmmm Link to post Share on other sites More sharing options...
Virus 2nd Gear August 3, 2005 Share August 3, 2005 Should be easily remove by turn the part above the base. Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie August 3, 2005 Share August 3, 2005 yes it does come off... But I can't remove the antenna... Link to post Share on other sites More sharing options...
C708 Neutral Newbie August 3, 2005 Share August 3, 2005 Hi, I just discovered that the a piece of the "ring" surrounding the base of the antenna of my Skoda Oct has broken...anyone noes where to get replacement for such thing? Tks! D, U may buy the antenna base, but changing it is gonna be a major prob.....cos u'll have open up underside of your roof panelling to access the base of the antenna from the inside. How I know this ?? HAve seen the mechs doing this in Servo replacing the same unit on an Ibiza. Believe u me.....its not an easy task ...... Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie August 3, 2005 Share August 3, 2005 Oh.... Not good... Not good... Link to post Share on other sites More sharing options...
Coke21 Neutral Newbie August 3, 2005 Share August 3, 2005 P, How did you have to pay to get the thing replaced? Link to post Share on other sites More sharing options...
C708 Neutral Newbie August 4, 2005 Share August 4, 2005 P, Pay ?? Nah, luckily for me I wasnt the owner of the Beezer mentioned earlier...... Link to post Share on other sites More sharing options...
Falc 3rd Gear August 13, 2005 Share August 13, 2005 Same problem here. But mine's a VW. Been bochap for few months liao. Link to post Share on other sites More sharing options...
Dtvox Neutral Newbie August 20, 2005 Share August 20, 2005 Me too...so now I know this is a common problem... Link to post Share on other sites More sharing options...
Skodarr Neutral Newbie August 20, 2005 Share August 20, 2005 Common indeed ... Try to park in enclosure area to avoid direct sun light ... The mechanism in Octy are mostly made of plastic with the assistance with rubber, therefore if contact with direct sunlight, the expansion and contraction of plastic will be more and the wear and tear have also increase ... Therefore, most rubbers and plastic wouldn't last long in this local climate... ↡ Advertisement Link to post Share on other sites More sharing options...
Shell @ Yishun Ring Road is Closing Down
Stiff Ring - Good to have?
1 Carat Diamond Ring..
2017 Honda Type R ring record broken
Kazakhstan:Mysterious black ring spotted floating in the sky
How to remove a ring stucked on a finger
5 Reasons to Skip the Diamond Engagement Ring
Pawnshop buy diamond
