French_porn Neutral Newbie May 1, 2003 Share May 1, 2003 i think i better send for a check up. Be4 any further damage is done. Thks Michel. ↡ Advertisement Link to post Share on other sites More sharing options...
Saaber Neutral Newbie May 1, 2003 Share May 1, 2003 If you don't mind Malaysian/Taiwanese Rim, go JB to buy, quite cheap... ... but avoid imported rims....very expensive.. Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie May 1, 2003 Share May 1, 2003 Am told sometimes its also that the installation not done properly - something to do with the proper alignment of the pads etc. Link to post Share on other sites More sharing options...
Michel Neutral Newbie May 1, 2003 Share May 1, 2003 No worries. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie May 4, 2003 Share May 4, 2003 Hi, your problem with the brake noise is clicking noise, squealing or knocking sounds? Some pads are made to fit a variety of cars so they may shave off some parts of the backing plate which will leave the pad with gaps between the caliper and vibrate. Mintex are made to fit unless the same caliper is shared between two different car models. ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Brake squeak every morning
Handbrake Lever up, does the brake light comes on?
