Jellyfish 1st Gear October 21, 2005 Share October 21, 2005 hi there just curious , how do you ppl drive in the flood , i think theres some technique to driving in the flood , do and don`t ,like how deep is too deep and what to do if your car stalls ↡ Advertisement Link to post Share on other sites More sharing options...
Redz Clutched October 21, 2005 Share October 21, 2005 drive slowly and tapped ur brakes often... Link to post Share on other sites More sharing options...
Decibel Neutral Newbie October 21, 2005 Share October 21, 2005 For manual car, I use gear 1 and modulate clutch + accelerator Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie October 21, 2005 Share October 21, 2005 avoid if possible, muddy/dirty water will dirty your engine bay. read from a book is, if u r driving a manual, keep your rev up, and gear 1 to drive thru the flood, if need to, use half clutch, don't release the accelerator, its to keep water from entering via the exhaust. after going thru a flood, tap the brakes to "drain" off excess water. as for auto.. i dunno Link to post Share on other sites More sharing options...
Crv2004 Clutched October 21, 2005 Share October 21, 2005 I just drive through Me SUV Ma so no need to worry so much That is one good thing about SUV Link to post Share on other sites More sharing options...
Ah_liang Clutched October 21, 2005 Share October 21, 2005 From wat I know, just drop your gear, step on the gas and drive thru. If you drop your gear in water, water can enter engine via your exhaust. Link to post Share on other sites More sharing options...
Crv2004 Clutched October 21, 2005 Share October 21, 2005 Oh ok If next time change to saloon car i take note of that Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 22, 2005 Share October 22, 2005 hi there just curious , how do you ppl drive in the flood , i think theres some technique to driving in the flood , do and don`t ,like how deep is too deep and what to do if your car stalls Shift to a lower gear, maybe 2nd gear. Keep the accelerator press at all times, try not to let go or else water may enter the exhaust and will stall engine. Use the clutch to control the speed, half-clutch if necessary. After going thru the water need to pump the brake a few times to get back the 'bite'. If unfortunately engine stall in the middle of water, I think that's the end. Link to post Share on other sites More sharing options...
Sei_fei_loh 1st Gear October 22, 2005 Share October 22, 2005 (edited) hi there just curious , how do you ppl drive in the flood , i think theres some technique to driving in the flood , do and don`t ,like how deep is too deep and what to do if your car stalls hmm.. i dunno if my technique is correct.. when there is a flood, normal saloon cars go damn slow, so i will go slow too, put to 1st gear, and if there is consistent movement between cars, then control the clutch to the pt where its biting and half not biting, resulting the car still moves and engine pushing exhaust gas consistently. sorry i cant really express myself well in this pt. hope u understand. and if so unlucky when there is a need to go to a complete stop, clutch in and maintain a certain RPM. say 2k and above 3k In a nutshell, when there is a flood, i will ensure exhaust gas is always coming out of the pipe, preventing water to enter the engine. and usually after clearing the area of flood, always tap my brake to ensure the brake is working well, as after brakes submerged in water, there is a tendency that it do not grip as well as normal. do take note!! As for SUVs and trucks, just dash through the water and make drivers in saloon green with envy.. haha.. Edited October 22, 2005 by Sei_fei_loh Link to post Share on other sites More sharing options...
Fortress Clutched October 22, 2005 Share October 22, 2005 You are absolutely right with the technique. Will like to suggest that avoid a flood road. In SIngapore, if any, is still quite safe, however, if you are in a foreign country where river or down hill flow of water will wash your car into the river(even if you on a road), with only 6" of water. Many had died from this. Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie October 22, 2005 Share October 22, 2005 Err... How come must drop gear b4 hitting the water? Why not maintain speed and plough through??? Link to post Share on other sites More sharing options...
Guyver 1st Gear October 22, 2005 Share October 22, 2005 hi there just curious , how do you ppl drive in the flood , i think theres some technique to driving in the flood , do and don`t ,like how deep is too deep and what to do if your car stalls Depends on the water level ... if it's higher than your exhaust... that's it liao..... Link to post Share on other sites More sharing options...
Gantan88 Clutched October 22, 2005 Share October 22, 2005 Auto gear leh? * Rub Chin * Cannot keep reving because car will increase in speed..... Link to post Share on other sites More sharing options...
Jellyfish 1st Gear October 22, 2005 Author Share October 22, 2005 well i read some where that if the entry speed is too high you will force water into the engine area and wet the electronics , worst case water gets injested into the engine via the resonator best to create a bow wave and just push along as the water after the bow wave is lower than the bow wave itself. Link to post Share on other sites More sharing options...
Jellyfish 1st Gear October 22, 2005 Author Share October 22, 2005 i think it can be done , just keep your rpm up while changing gear , takes some pratice though as the normal tendency is to let go the acclerator Link to post Share on other sites More sharing options...
Sei_fei_loh 1st Gear October 23, 2005 Share October 23, 2005 haha... for autogear, im nt soo sure.. when i was still driving my dad's auto car last time, i put to neutral and rev like the manual and push to D to move. its not advisable i suppose, cos there tend to be noisies from the gear.. but my dad told me to do that if bo bian.. better than let the car die there and 'drown' the engine. d: > Link to post Share on other sites More sharing options...
Fortress Clutched October 23, 2005 Share October 23, 2005 Higher gear at low speed will stall the car. Hence, it is adviced to go in slow at low or 1st gear. However, due to the exhaust gas/pipe, might be below water, constant higher pressure needs to maintain to prevent choking or stalling the car. Therefore the need to keep your accelaerator on and maintain speed through clutch or half clutch. Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie October 23, 2005 Share October 23, 2005 Oh... ok... So basically it's not a good idea to just fly through the puddle water... ↡ Advertisement Link to post Share on other sites More sharing options...
Drink Driving Is An Act Of Irresponsibility!
Boomers on the road should take mandatory tests
Worth to be a Grab Driver now?
Class 4 Driving License
