Yusliza Neutral Newbie February 9, 2006 Share February 9, 2006 (edited) Hi guys Last week, I parked my car under a lamp post at my uncovered carpark and left it there for 2 days. After 2 days, I found silver paint spots all over the car's body and mirrors/glass to my horror!! The paint color matched the lamp post. I then wrote a mail to the town council to ask if any work has been done to the lamp post and they said no, but before that the spots were not there. Now I don't know what to do. How can I get the spots removed? Attached pic is the spots as seen from the top of my car. Your help is appreciated. Edited February 9, 2006 by Yusliza ↡ Advertisement Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear February 9, 2006 Share February 9, 2006 One of my friend also kenna this before He brought his ride to a professional groomer and managed to clear it off Link to post Share on other sites More sharing options...
Yusliza Neutral Newbie February 9, 2006 Author Share February 9, 2006 One of my friend suggested using turpentine to remove but i'm just afraid it might mess up the paintwork. does the pro groomer charge more? so frustrated cos i know someone did it and i don't believe it was vandalised cos the paint drop goes across from bonnet to the back bumper nicely, as if it dropped from somewhere Link to post Share on other sites More sharing options...
Evildoer Neutral Newbie February 9, 2006 Share February 9, 2006 mix a bit of thinner with water and try to rub the paint spots away....i dun see the attached pic le... Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear February 9, 2006 Share February 9, 2006 Let me check with my friend & come back to you shortly IMHO, better not try turpentine if you are not really a DIY person cos later sekali mess up your paintwork and it burns a bigger hole in your pocket Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear February 9, 2006 Share February 9, 2006 Jus called up my friend and he say that the groomer did not charge him extra However, that groomer closed down liao Link to post Share on other sites More sharing options...
Burgerdog Neutral Newbie February 9, 2006 Share February 9, 2006 if you have the small bottle of spot remover given by Tuff Kote, then it should come off easily... i've tried it with my car and it works perfectly... Link to post Share on other sites More sharing options...
Whitepowder Neutral Newbie February 9, 2006 Share February 9, 2006 Most silver paint use for lamp post comprise petroleum resin, alu pigment and turpentine. Rub gently turpentine should be able to remove the spot. I assume that the paint on your car is OEM. It should be able to with stand turpentine. To play save, try it on a sport where it is not easily seen to see if it works or affect the paint work. It may need to polish your car after the spots are removed. Link to post Share on other sites More sharing options...
Johnjohn Neutral Newbie February 9, 2006 Share February 9, 2006 not sure bro. i did that on my pearl white coat and got off the pearl leaving a very white. suggest you hop down to the car agent. for my case, i ended up respraying the whole door panel Link to post Share on other sites More sharing options...
Marcostan 4th Gear February 9, 2006 Share February 9, 2006 YUSLIZA, U can try clay barring, ususally for over spraying can take out easily. But never experience yours. Clay bar do no harm to the paintwork, so why not try out see how. MarcosTan Link to post Share on other sites More sharing options...
Yusliza Neutral Newbie February 9, 2006 Author Share February 9, 2006 scared to use thinner or turpentine leh. sorry here's the pic. [inline IMAGE_00038.jpg] Link to post Share on other sites More sharing options...
Yusliza Neutral Newbie February 9, 2006 Author Share February 9, 2006 one of my friend recommended amazing glaze but don't know if the spots can go away or not. Link to post Share on other sites More sharing options...
Yusliza Neutral Newbie February 9, 2006 Author Share February 9, 2006 bro, my car not coated with tuff kote lah, but where can i get this spot remover? Link to post Share on other sites More sharing options...
Yusliza Neutral Newbie February 9, 2006 Author Share February 9, 2006 alamak, if small spot affected still heartache leh Link to post Share on other sites More sharing options...
Yusliza Neutral Newbie February 9, 2006 Author Share February 9, 2006 bro, me too lazy to do clay barring myself lah. would rather let the pro clay bar for me Link to post Share on other sites More sharing options...
Skip Neutral Newbie February 9, 2006 Share February 9, 2006 Turpentine should be safe for your car's paint, but thinner is an absolute no no! Thinner is too strong, it will dissolve your original paintwork. Besides, I don't think its possible to mix thinner and water at all! I second marcostan's suggestion of clay-barring, I believe it will get rid of those spots with minimal effort. Clay-barrng is actually quite easy, just mix some car shampoo and use as the lubricant. To clay bar the whole car will probably take you no more than 20 minutes, its the most cost effective solution to you problem IMO. Link to post Share on other sites More sharing options...
Yusliza Neutral Newbie February 10, 2006 Author Share February 10, 2006 Ok, thanx for the advise. Will need to 'sweat' a bit to do this lah anyway, i'm thinking of sending the car for grooming as i have not done it since day 1 ↡ Advertisement Link to post Share on other sites More sharing options...
