Gary84 1st Gear April 14, 2006 Share April 14, 2006 hmmmm...gd one bro...now that my shocks are faulty....moving over a slight hump can be very irritating...very bumpy ride now....haiz~ ↡ Advertisement Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie April 14, 2006 Share April 14, 2006 can i use King Koil springs? Link to post Share on other sites More sharing options...
Octopus 3rd Gear April 14, 2006 Share April 14, 2006 [reply] hmmmm...gd one bro...now that my shocks are faulty....moving over a slight hump can be very irritating...very bumpy ride now....haiz~ Can try some lubrication on your shock absorber as temporary counter-measure, until you change to a new set. Link to post Share on other sites More sharing options...
Octopus 3rd Gear April 14, 2006 Share April 14, 2006 [reply] can i use King Koil springs? Of course, if you're looking for a good and undisturbed sleep. Do let me know if you know where to get cheap King Koil spring, OK? Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie April 14, 2006 Share April 14, 2006 Link to post Share on other sites More sharing options...
En0203 2nd Gear April 14, 2006 Author Share April 14, 2006 aiya too bad...what has happened has happened already.....juz hope that this car wont fail me again... no problem lar, just be more gentle and she'll repay ur kindness Link to post Share on other sites More sharing options...
En0203 2nd Gear April 14, 2006 Author Share April 14, 2006 wah $250 and can still be cheaper?... ya, the beauty of using cheap cars Link to post Share on other sites More sharing options...
En0203 2nd Gear April 14, 2006 Author Share April 14, 2006 Wow, that's good. But if for my case, even if such tool is provided I still don't know how to change my shock absorber... no need to know lar, labour also cheap cheap just let the proffesional do it better i was doing it trial and errors, may end up damaging it who knows Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie April 14, 2006 Share April 14, 2006 (edited) Edited April 14, 2006 by Wolverine Link to post Share on other sites More sharing options...
En0203 2nd Gear April 14, 2006 Author Share April 14, 2006 Link to post Share on other sites More sharing options...
Gary84 1st Gear April 14, 2006 Share April 14, 2006 bro hw do i go abt lubricating it huh? i dunoe even knw which part to apply plus use wich lubricating gel....pls enlighten... Link to post Share on other sites More sharing options...
Gary84 1st Gear April 14, 2006 Share April 14, 2006 yah...nw i treat it wif care le lor...hahah Link to post Share on other sites More sharing options...
Gary84 1st Gear April 14, 2006 Share April 14, 2006 haha... enjoy ur ride bro~! Link to post Share on other sites More sharing options...
En0203 2nd Gear April 14, 2006 Author Share April 14, 2006 yea, that's the way it should be Link to post Share on other sites More sharing options...
Octopus 3rd Gear April 15, 2006 Share April 15, 2006 [reply] bro hw do i go abt lubricating it huh? i dunoe even knw which part to apply plus use wich lubricating gel....pls enlighten... Just need to jack up the car at all 4 points one-by-one, just like changing tyre. After the tyre had been jacked-up, you should be able to see the shock absorber metal part by shifting the rubber cover slightly to one side. Then just spray the metal sliding part with some lubricant, I used silicon spray, but I think lithium grease spray would do fine as well. Link to post Share on other sites More sharing options...
Nissantoot Neutral Newbie April 15, 2006 Share April 15, 2006 hey dudes, going to change my Nissan 1.5, 4 x shocks soon. Any recommendation? Not going for performance shocks...should I go for KYB (about 270 bucks) or original (about 340)? Is this KYB shock durable? I heard there's gas versus liquid one...which one to go for? Any specific model to recommend for KYB? Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear April 15, 2006 Share April 15, 2006 kyb is fine. your "original" nissan ones are rebadged kyb's. (just like your over expensive nissan clutches are rebranded exedy ones). If you can get the kyb gas-a-just absorbers go for them. as comfy as the stock ones, but they move less when cornering so theres less body roll. And they cheaper than the AGX's Link to post Share on other sites More sharing options...
Nissantoot Neutral Newbie April 15, 2006 Share April 15, 2006 "If you can get the kyb gas-a-just absorbers go for them." bro, what does gas adjust mean? does that mean the mechanic fitting it in must know how to adjust the thing? I just called up this HC auto and they say can help me install for $80. any bro got experience in using this WS? ↡ Advertisement Link to post Share on other sites More sharing options...
Change Disc Rotors
Change Disc Rotors
Tool to change Spark Plug
X for twitter change request
How much to replace shock absorbers?
