Vblaster_w211 2nd Gear May 7, 2006 Share May 7, 2006 Air Intakes and ECU tuning are legal. Exos needs certification and inspection from LTA (quite possible to do) complete with homologation papers and certs like JASMA. Same for Turbo/SC (but much more difficult to do). ↡ Advertisement Link to post Share on other sites More sharing options...
Vtim 3rd Gear May 7, 2006 Share May 7, 2006 hi all.. i own a 2005 Hyundai Accent with auto transmission and what upgrades do u guys recommend? i want the engine to sound loud and sweet :) a few questions.. 1) Is the 'Light tune package' from this company called 'McWell ventures' good? 2) Is there any aftermarket exhaust sysetem suitable for my car and how much would it cost? 3) Any other performance upgrades u guys recommend? Thanks! For Hyundai, best is go to Harmony Motors http://www.myharmony.com.sg/ Link to post Share on other sites More sharing options...
Reliable Clutched May 7, 2006 Share May 7, 2006 hi all.. i own a 2005 Hyundai Accent with auto transmission and what upgrades do u guys recommend? i want the engine to sound loud and sweet :) a few questions..1) Is the 'Light tune package' from this company called 'McWell ventures' good? 2) Is there any aftermarket exhaust sysetem suitable for my car and how much would it cost? 3) Any other performance upgrades u guys recommend? Thanks! Suggestions: 1) dont go to McWell unless u wanna be a "carrot" 2) Aftermarket exhaust system is easily available for all cars. U can go Jeep Chee, Fong Kim or Man Exhaust. Malaysia will be cheaper. U can also operate on your own exhaust BUT when comes to inspection u might have problem swapping or u have to ask mechanic help u send in. U can also check if there is legal LTA approved exhaust for accent. 3) As some bros suggested, u can go for open pod. But u have to ask what u want to play with. Low to Mid? or Mid to High? if u normally don't even hit more than 3k rpm or 100km/h i will suggest u go for low to mid mod will do. Other suggestions depends on your preference 3a) use k&n or hurricane drop in filter -(low end mod) 3b) use simota carbon charger ( low to mid) 3c) CAI - cold air intake 3d) 4-2-1 extractor (low to mid mod but illegal) 3e) 4-1 extractor (mid to high mod but illegal) 3f) change exhaust pipping to slightly bigger 3g) High flow CAT (illegal) 3h) change pulley (low end mod) 3i) Port & Polish and Bore Throttle body 3j) PiggyBack or change ecu ( the last item to mod) To make ur car go faster u must also lighten your car too. handling must improve if you intend to take your car at fast corners- coilovers, lower brace, strut bars and antiroll bars are for improving handlings. Important to take note. Before u start any performance mods best is to improve your braking and tyres. U might be able to drive fast and furious but nothing is more important than able to brake on time. just my 2 cents worth of suggestions Link to post Share on other sites More sharing options...
Gary84 1st Gear May 11, 2006 Share May 11, 2006 bro, forget abt the Light tune Package from McWell la...look at my signature...i did mine by them and think was quite useless... Link to post Share on other sites More sharing options...
Sable Neutral Newbie May 13, 2006 Share May 13, 2006 can anyone help with my question. I came across another tread that mentioned that you can draw cold air by connecting your air con pipe to the air filter pipe. Is that possible? will there be any consequences? thanks Link to post Share on other sites More sharing options...
Spikedoll Clutched May 13, 2006 Share May 13, 2006 ehhh...those package fr mcwell is......exp & use xxxx Link to post Share on other sites More sharing options...
Requiemdk 1st Gear May 13, 2006 Share May 13, 2006 Ok if I understand what you're saying correctly, you're saying that we can draw cold air by re-routing one of our aircon pipes to our air intake system? ... ...... Ok maybe you'd like to link that thread here so we can all go there and give the fella who suggested it a good flaming. I mean, the suggestion sounds as good as drinking our own piss to quench our thirst. Simple answer to your question: no. The aircon doesn't provide enough air for the engine, plus I'm sure, being in Singapore, that you've set your aircon to re-circulate mode. In that case, you're going to end up competing with your engine for air! Link to post Share on other sites More sharing options...
Gary84 1st Gear May 14, 2006 Share May 14, 2006 bro i dunoe if tat's possible...maybe need more lao jiao's advice...Anyway draw cold air isnt it done wif the CAI? Link to post Share on other sites More sharing options...
Gary84 1st Gear May 14, 2006 Share May 14, 2006 yah i would say a total waste of $$ on the lousy mods.... Link to post Share on other sites More sharing options...
Lucien Neutral Newbie May 14, 2006 Share May 14, 2006 Hyundai Accent moddin ar. Accent not a high rev type. Doing open pod maybe not yield u much, and with the low rpms already not so strong, u will pick-up like a snail. i dun think u will rev to change gears @5k rpm in order for your open pod to work. Exhaust modding is considered illegal. Unless you are able to purchase original accent aftermarket parts. but i doubt so. The accent manifold is 4-1. Gd for higher rpm performance. if you want to get more power at lower rpm, meaning you want to shift the power band to lower rpms, you can consider changin to 4-2-1. So far not much feedback on Accent running on piggys or ECU re-program. perhaps they can tune for performance, but i would guess only improvements on the high rpms. Best mod for better sounding engine....get a bigger CC car. Link to post Share on other sites More sharing options...
Gary84 1st Gear May 14, 2006 Share May 14, 2006 yah maybe u can tell tat to the Accent owner...hehe Link to post Share on other sites More sharing options...
Hexy 1st Gear May 14, 2006 Author Share May 14, 2006 lol.. i dont like the idea of competiting for air with my engine! Link to post Share on other sites More sharing options...
Hexy 1st Gear May 14, 2006 Author Share May 14, 2006 (edited) sure i would love to get an evo.. only thing stopping me is $$$$.. so im stuck with accent for now.. Edited May 14, 2006 by Hexy Link to post Share on other sites More sharing options...
Requiemdk 1st Gear May 14, 2006 Share May 14, 2006 Wise choice. I don't think our 2 cylinder, small bore short stroke breathing system can compete with even a 1 litre 4 cylinder engine. Link to post Share on other sites More sharing options...
Hexy 1st Gear May 21, 2006 Author Share May 21, 2006 Is there anything else to make my car sound sporty? Other than the open pod filter and exhaust.. thanks Link to post Share on other sites More sharing options...
Bluecity Neutral Newbie May 21, 2006 Share May 21, 2006 Maybe you should consider hurricane stainless steel drop in filter. Just replace your original paper filter with this high air flow filter will do. NA cars, especially auto... don't quite recommand using open pod. Alternatively, consider close pod or carbon intake. Open pod will either lose in low or high end power. Drop in, will not lost in low end, but will improve much on highend. Close pod and Carbon intake, i haven't try before. Might be better than openpod i pressume. Link to post Share on other sites More sharing options...
Hexy 1st Gear May 21, 2006 Author Share May 21, 2006 Why is open pod filter not recommended in auto cars and NA engines? and what is NA? thnx bro.. Link to post Share on other sites More sharing options...
Preakshox 2nd Gear May 21, 2006 Share May 21, 2006 yea, and i was planning to replace my stock with an open pod. care to enlighten? looking for better low-end torque though, with a auto ride. ↡ Advertisement Link to post Share on other sites More sharing options...
Music Concerts
Music Concerts
MOM help FTs look for jobs ?
RS Chip Tuning
RS Chip Tuning
RAM/MicroSD issues
RAM/MicroSD issues
