Wui75 Neutral Newbie May 28, 2006 Share May 28, 2006 I'm going for 40k servicing either in June or July. May I know roughly how much will it cost? Which parts need to be replaced? I heard the gearbox needs to be replaced. Also, which service centre would you recommend? Mine is Fit auto-gear, bought from a PI. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear May 28, 2006 Share May 28, 2006 thats a short-lived gearbox anyway..sparkplugs, oil filter+oil, coolant, gear oil, air filter, aircon filter Link to post Share on other sites More sharing options...
Fatfat Neutral Newbie May 28, 2006 Share May 28, 2006 Hi Why do u need to replace the gearbox? did u mean gearbox oil instead? at 40k, do check the brake rotors as well. Good luck. Link to post Share on other sites More sharing options...
Wui75 Neutral Newbie May 28, 2006 Author Share May 28, 2006 Thanks. But can tell me roughly the estimated cost? Assuming the usual things need to be replaced? I'm not that familiar with car parts so I do need some advices in order not to be chop vegetable head. Thanks. Link to post Share on other sites More sharing options...
Jusnel 6th Gear May 28, 2006 Share May 28, 2006 well, the price of the normal servicing that you need to pay such as oil, spark plug, oil filter, and now plus the air con filter, air filter, gearbox oil... maybe in the range of $200+? it's definitly not more than $300! BTW, how's yr FC for Fit? Link to post Share on other sites More sharing options...
Silverado1 Neutral Newbie May 28, 2006 Share May 28, 2006 40 K Servicing First thing: Renew Engine Oil,(Min. Oil lasts 5K, & Fully Syn.Oil lasts 10K- The choice is yours) Replace Oil Filter & Spark Plugs(Stock lasts 20K, Iridium/Platinum last 100K). Then replace your Air Filter Element. replace ur Brake Fluid, Transmission/differential Oil, Power Steering Fluid, Clutch Fluid, Engine Coolant. Check ur washer tank water, battery distilled water, clean & lub all door hinges, locks and catches, including ur Battery Terminals. Also check ur Wiper Blades, all lights, engine compartment hoses(check for leaks or unusual expansions), In-line fuel filter(Replace if very dirty), fuses & contact, and ur Battery Charging Rate. Free-play of Clutch/cable & belt tensions. Do a rotation & balancing of ur Tires, also check Tire Pressure, & condition. Do check wheel bearing condition and renew if necessary. Do an ECU diagnostic Check & tuning, adjust ur Idling Speed & Ignition timing. Pressure Test ur Engine Cooling System. Check ur Steering rack & pinion, ball joints, tie rods, dust cover, drive shaft, dust cover & shocks. Finally, Clean & service all 4 wheels Brakes, adjust handbrake, renew shoes & pads if necessary. Hope this helps! Happy Driving! ↡ Advertisement Link to post Share on other sites More sharing options...
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
Workshops with engine oil flushing machine
Volvo Servicing
Volvo Servicing
