Elfenstar 3rd Gear June 3, 2006 Share June 3, 2006 i know i know i'm on the same train of thought ↡ Advertisement Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie June 3, 2006 Share June 3, 2006 Wanna drag with my stock lancer ? I had a GDB up my ar5e today while on my way home. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear June 3, 2006 Share June 3, 2006 wrx and evo rivalry has been there for a while. i'm not surprised... ah well better than a commonwhore than cant even move fast in a straight line Link to post Share on other sites More sharing options...
Yc86 Clutched June 3, 2006 Share June 3, 2006 Let's remove our suspension n drive w/o it.. Wah, the feeling darn shiok man! i think it's possible right?... wonder how the handling will be.... even the small 1/10 or 1/8 R/C cars have a full coilover setup... can change the springs, ride height, dampening, shock absorber fluid... etc. damn cute Link to post Share on other sites More sharing options...
Chisiang 2nd Gear June 5, 2006 Share June 5, 2006 Ford RS200??? Dun look like that leh... and its TC not SC. did u mean Lexus ES200??? Altezza RS200. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear June 5, 2006 Share June 5, 2006 Yum... whereabts in the world are u again??? Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie June 5, 2006 Share June 5, 2006 Wheres the love ... Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear June 5, 2006 Share June 5, 2006 before you get the front seat... "SHOTGUN" Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie June 5, 2006 Share June 5, 2006 Link to post Share on other sites More sharing options...
Louis_freddie Neutral Newbie June 6, 2006 Share June 6, 2006 FI need to install wan rite?? if yes wat is the tin?? den wat is piggy bag n wat is ECU?? how to tune it? tune le will how?? sorry im so new tat i don understand sorry pls enlighten thank you Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie June 6, 2006 Share June 6, 2006 Use the Search. Link to post Share on other sites More sharing options...
Jusjazz Neutral Newbie June 6, 2006 Share June 6, 2006 (edited) wah a bit hard... for power increase per $, TC then SC then nitrous. Intercoolers do not increase power although they allow you to make more power safely. How do you compare suspension when it does something totally different to the rest of the mods?? Upgraded suspensions vs stocky soft suspensions made alot of difference for high conering speeds, as well as sharp corners IMHO. For example, two significant stock cars, one with a Low Boost turbocharger, & the other without but had a good set of suspensions may not loose out to the turbocharged car in the race track cos conering speeds is also very important during a race in order to take home the trophy. Edited June 6, 2006 by Jusjazz Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear June 6, 2006 Share June 6, 2006 BMW is right. go to www.howstuffworks.com and seach for Forced Induction and ECU and read up. fastest way with diagrams etc. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear June 6, 2006 Share June 6, 2006 It does. First thing that gets upgraded for me is suspension. What i meant was how do u compare a suspension mod to a power mod.. Link to post Share on other sites More sharing options...
Thumbs Neutral Newbie June 7, 2006 Share June 7, 2006 However, I wish to point out, before we proceed, that the internet has plenty of information for research but there are also a lot of junks. Viewers should decides for themselves what information they read is CREDIBLE, and what are junks. This is because most of our references, including mine, are based on articles published by companies and individuals on the internet. Agreed. Let's see what you posted. Basically the few variables involved are: 1) Pressure 2) Volume 4) Temperature These are the variables of Ideal Gas Law, whereby: P1V1/T1 = P2V2/T2 P1=INITIAL PRESSURE V1=INITIAL VOLUME T1=INITIAL TEMPERATURE P2=FINAL PRESSURE V2=FINAL VOLUME T2=FINAL TEMPERATURE For argument sake, imagine the conditions as below: Running 1 BAR boost before intercooling = P1 Intake Air Temperature before cooling is 150 deg C = T1 After intercooling, let's assume there is a drop in 40 deg C = 150-40 = 110 = T2 With Volume being constant = V1=V2 Given P1V1/T1=P2V2/T2 --------(1) SUBSTITUTE P1=1, T1=150, T2=110 INTO (1) V1/150=P2V2/110 110V1=150P2V2 --------------------(2) SUBSITUTUE V2=V1 INTO (2) 110V1=150P2V1 DIVIDE BOTH SIDE BY V1 110V1/V1=150P2V1/V1 110=150P2 THEREFORE P2 = 110/150 = 0.7333 BAR This concludes that in order to achieve the same volume of air into the engine after intercooling with a drop in 40 deg C, the pressure after intercooling must drop to 0.733 BAR. Let's assume a better intercooler is able to lose 70 deg C compared to the previous example, while all other remain the same. After intercooling, let's assume there is a drop in 70 deg C = 150-70 = 80 = T2 With Volume being constant = V1=V2 Given P1V1/T1=P2V2/T2 --------(1) SUBSTITUTE P1=1, T1=150, T2=80 INTO (1) V1/150=P2V2/80 80V1=150P2V2 --------------------(2) SUBSITUTUE V2=V1 INTO (2) 80V1=150P2V1 DIVIDE BOTH SIDE BY V1 80V1/V1=150P2V1/V1 80=150P2 THEREFORE P2 = 80/150 = 0.5333 BAR This further shows that a more cooling intercooler will have an even higher drop in pressure when more heat is dissipated. OK, stop. Your flawed calculation is based on the idea that volume of the gas remains constant given that there is a drop in temperature. By Charles Law, you CANNOT do this i.e. hold the volume constant yet lower the temperature. Link to post Share on other sites More sharing options...
Thumbs Neutral Newbie June 7, 2006 Share June 7, 2006 Read the thread title and the original post. It says "performance mod", not "power mod". Since suspension does help a car handle better, it is considered a performance mod. Link to post Share on other sites More sharing options...
Jusjazz Neutral Newbie June 7, 2006 Share June 7, 2006 (edited) Thanks for pointing that out THUMBS, as I was about to do that too. Edited June 7, 2006 by Jusjazz Link to post Share on other sites More sharing options...
Thumbs Neutral Newbie June 7, 2006 Share June 7, 2006 OK replying to my own post since MCF doesn't seem to allow editing of post. Mis-read the part about constant pressure. My bad. ↡ Advertisement Link to post Share on other sites More sharing options...
Music Concerts
Music Concerts
RS Chip Tuning
RS Chip Tuning
Most expensive car in the world: ROLLS-ROYCE SWEPTAIL
Nissan QashQai 2014 Part 2
Most Expensive City In the world
