Maddriver 4th Gear July 25, 2006 Share July 25, 2006 (edited) i have 2 kakis using meguire pad..so far so good..there wasn't any complain of breaking up and infact of them pushes real hard on them. Edited July 25, 2006 by Maddriver ↡ Advertisement Link to post Share on other sites More sharing options...
Biccat Neutral Newbie July 25, 2006 Share July 25, 2006 I ain't no detailing guru therefore am not in a position to compare abt the diff types of pads available in the market. But from a mechanical standpoint, the design of the Meguiar's is not ideal for durability:- 1) The foam backing does not extend all the way to the outside of pad. At the point where the backing meets the pad, mechanical stress between the backing and pad will cause the pad to shear off with constant use. 2) When the pad is attached to the DA, there is only a very small area of the backing being exposed. So when the user tries to remove the pad from the DA, unwittingly the user pulls directly on the pad instead of grapping the velco backing area. I stand to be corrected. Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 25, 2006 Share July 25, 2006 1)did i ask u to compare the difference between the both,am just saying what pad i am using..and i am not saying meguire is good..i m not saying u are wrong 2)yes,at the mechanical standpoint,the area of contact is very little..theoretically it shears but i have a pad,valco is 4" and the pad is 6"..and i can tell u i got this pad from detailogy..i have been using plenty of time,i want it to break off but it just doesn't.. Link to post Share on other sites More sharing options...
Biccat Neutral Newbie July 25, 2006 Share July 25, 2006 Bro, neither am I saying that you are wrong or that Meguiar's is no good. I am just offering my personal opinion on why the pads could have failed. In the hands of an experienced user like you, I am sure it will last a long time but for a novice, he/she may have unwittingly abused the pads resulting in premature failure. Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 25, 2006 Share July 25, 2006 bro,i am just like u too,learning...but my another guess, might be the machine too..my kaki uses ryobi and the other uses bosch..both using meguire pad but look like the pad on ryobi tend to shear faster..after all there are too many factors,sometime just cant be bother..spoiled and throw..so will have the chance to try new stuff have a good day Link to post Share on other sites More sharing options...
Biccat Neutral Newbie July 25, 2006 Share July 25, 2006 Guess you are right, too many factors to consider. But I am just a poor miserly man with many mouths to feed at home, very giam siap wan. Must stretch until cannot tahan anymore. Link to post Share on other sites More sharing options...
Garlic 1st Gear July 26, 2006 Share July 26, 2006 (edited) Yes, you are right. One have to be careful when removing the pad after user or it will tear very easily. Also, ensure the pad is of the right size and fits properly or the backing will tear the pad(this happens very quickly if you use force). Would be good if the velcro pad on the pad is slightly bigger than the machine's backing. Will try LC pads the next time, one of my Meg's polishing pad is already torn quite badly. Edited July 26, 2006 by Garlic Link to post Share on other sites More sharing options...
Tehtarik69 Neutral Newbie July 26, 2006 Share July 26, 2006 Where to buy LC pads? Thanks Link to post Share on other sites More sharing options...
Lukie102 Clutched July 26, 2006 Share July 26, 2006 actually using meguire pad on bosch and ryobi gives the same result. it tears. think is the padding behind. Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 26, 2006 Share July 26, 2006 ic ic..but seems club is having a good time with it Link to post Share on other sites More sharing options...
Clubace Clutched July 26, 2006 Share July 26, 2006 How you wash the pads actually affect the durability of the pads too. I hand wash it. Link to post Share on other sites More sharing options...
Biccat Neutral Newbie July 26, 2006 Share July 26, 2006 Finally, found someone who experienced the same thing as me. Link to post Share on other sites More sharing options...
Lukie102 Clutched July 27, 2006 Share July 27, 2006 (edited) i handwash too. in fact i handwash all my detailing cloths and pads. I dont hang them under the sun too. Edited July 27, 2006 by Lukie102 Link to post Share on other sites More sharing options...
Lukie102 Clutched July 27, 2006 Share July 27, 2006 (edited) yeah. another guy in the forum also experienced the same thing. i was surprised when i see the foams flying around Edited July 27, 2006 by Lukie102 Link to post Share on other sites More sharing options...
Clubace Clutched July 27, 2006 Share July 27, 2006 Hand wash without detergent for the pads. Link to post Share on other sites More sharing options...
Lukie102 Clutched July 27, 2006 Share July 27, 2006 i use detergent. but anyway, the pad disintegrate the 1st time i use it. Link to post Share on other sites More sharing options...
Clubace Clutched July 27, 2006 Share July 27, 2006 You hiong. Link to post Share on other sites More sharing options...
Weiming 1st Gear July 27, 2006 Share July 27, 2006 Should try LC. Have the variable contact types for yellow and white and both still work fine after a year. I also handwash in Dynamo liquid after each use. The pads still look brand new with the velcro backing and foam surface intact. ↡ Advertisement Link to post Share on other sites More sharing options...
Sugar and Salt, which is more evil?
2 lanes turn right to 3 lanes - which lane to go?
Which brand of honey to buy?
Which airline is the best?
