Jusnel 6th Gear June 23, 2006 Share June 23, 2006 hi all, my right passenger door handle spoilt liao... cant open from outside and inside.... sianzz... any cheap and reasonable ws to fix up this? my central locking is still working well.... just that the door handle is very loose and the door cant be opened. my ride is civic thanks.... ↡ Advertisement Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie June 23, 2006 Share June 23, 2006 The handle probably popped off the shaft inside the door, if you can take the door interior panel out you might see the shaft dangling loose. Just reattach it and it'll work. Link to post Share on other sites More sharing options...
Idolclb Neutral Newbie June 23, 2006 Share June 23, 2006 Your ride still under warranty? Can ask KM to get it done. Link to post Share on other sites More sharing options...
Jusnel 6th Gear June 23, 2006 Author Share June 23, 2006 no la.... mine is a grandfather civic, EG model.... Link to post Share on other sites More sharing options...
Jusnel 6th Gear June 23, 2006 Author Share June 23, 2006 thanks bro.... i know i can try to DIY this thing, but i afraid of breaking those panel pins when i use too much strength or pull wrongly..... quite tempted to DIY it.... Link to post Share on other sites More sharing options...
Idolclb Neutral Newbie June 23, 2006 Share June 23, 2006 Yah...a friend of mine did break some snap on catches which DIYing sound proofing. But he told me that those catches are easily available in auto shop. May be you can check it out first....good luck.... Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie June 23, 2006 Share June 23, 2006 Door panel is usually held together with one or two screws only, the rest are the snap pegs. Just unscrew and pull the panel straight and out Link to post Share on other sites More sharing options...
Gary84 1st Gear June 24, 2006 Share June 24, 2006 to play safe, u better go to some reliable workshops and get the mechanic to do it..in case u break some pins while DIY-ing....then jialat liao.. Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 28, 2006 Share June 28, 2006 hi all, my right passenger door handle spoilt liao... cant open from outside and inside.... sianzz... any cheap and reasonable ws to fix up this? my central locking is still working well.... just that the door handle is very loose and the door cant be opened. my ride is civic thanks.... one of the door handle mechanism spoilt..most likely need replace the door handle..i replaced twice liao Link to post Share on other sites More sharing options...
Jusnel 6th Gear July 1, 2006 Author Share July 1, 2006 $$ away..... i dun want to replace spoilt mechanism.... Link to post Share on other sites More sharing options...
Mivec9 1st Gear July 4, 2006 Share July 4, 2006 then how..juz let it be? ↡ Advertisement Link to post Share on other sites More sharing options...
'protection' against door bang
Door Protector Stripes, an important exterior feature against dings?
Digital Door Lock
Digital Door Lock
Hdb main door
Hdb main door
Double sided tape for door visor
