Nerdie Neutral Newbie August 8, 2006 Share August 8, 2006 Hi my 1.4M rio5 cannot start this morning, it said that battery was flat...(somemore i need to drive today, sian...) i thought it is maintenance free one? how come need to maintain.. Does it mean i need someone to jumpstart for me and go workshop and change battery water? or distilled water?? //me newbie... ↡ Advertisement Link to post Share on other sites More sharing options...
Exetor Neutral Newbie August 8, 2006 Share August 8, 2006 I heard jumpstarting is not good for our ECU. I dunno but thats what I heard.. It may just kill the ECU.. Lolz.. ANyway, perhaps you could call up your mechanic to come and replace the battery? =) Link to post Share on other sites More sharing options...
Silver_blade Turbocharged August 8, 2006 Share August 8, 2006 Btw, how lold is your batt? Maintenance free doesn't mean it will not go flat. You can enegange your can in 2nd gear, get someone to push it and try to start + release the clutch (like you'll do during normal driving @ 1st gear) and step down the acc pedal. Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear August 8, 2006 Share August 8, 2006 maintenance free doesnt mean it'll last forever... when its time to go, its time to go... when servicing your car, ask the mechanic to check on the condition of the battery too... it'll save you the troubles that u are experiencing now... Link to post Share on other sites More sharing options...
Fortress Clutched August 8, 2006 Share August 8, 2006 hope it helps http://www.mycarforum.com/forum/gforum.cgi...battery;#990492 Link to post Share on other sites More sharing options...
Nerdie Neutral Newbie August 9, 2006 Author Share August 9, 2006 Just to update.. I didn't leave the lights on overnight, and the car was fine less than 10 hrs ago.. Heh Got some AA guy to come (under 20km, 6mths old so it's still free) He opened the petrol tank.. Then he turned on the ignition and stepped on the accelerator and it started. He explained that there was "air in the engine" whatever it means, so have to step on the accel and ignite at the same time. He advised me not to leave the tank less than half empty (?!?!!) and not to leave it idle for more than 2 days. He also related that he has seen a number of rio5 with this problem, don't know how true it is. Anyway my car is working fine now, will send it for servicing soon, *scared* Link to post Share on other sites More sharing options...
Kianbeng Clutched August 9, 2006 Share August 9, 2006 If your battery was flat then the AA mechanic wouldn't be able to even crank the engine without connecting to another battery in parallel. Or do you mean you were trying to start but only hear engine cranking but not starting up? Link to post Share on other sites More sharing options...
Fortress Clutched August 10, 2006 Share August 10, 2006 Didn't say you did, was just trying to be helpful. ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
Battery for Honda Vezel
Hdb flat renovation
Hdb flat renovation
