Turbobrick Neutral Newbie March 10, 2002 Author Share March 10, 2002 Hi Cool, U mean a special tool to push the insulation material or something in the door panel to adjust? ↡ Advertisement Link to post Share on other sites More sharing options...
Cool Neutral Newbie March 10, 2002 Share March 10, 2002 TUrbobrick.. Did not read your posting... allow me to share my past experience My doors did vibrate before once... the problem is not the door but the floor that caused the vibration and the tyres you use. My mechanic taught me the rite way to do insulating... not just cover but at strategic parts.. Example: Rear wheel areas (under the seats) Floor (4 seats) Rear seat joining the boot Leave the door uninsulated cos you may block the air flow if not done properly especially in japs cars... else the glass may shattered at high speed. (this was what happened to a friend of mine). If you are interested... I can share with you a cheap tip.. use Office Carpets. they are good at absorbing noise.. do not spend money on those expensive ones.. I use SoundGard with a layer of office carpet .. very quiet compared to the stock ones... but I believe 2 layer of office carpets will do the trick. my 2 cents .. of .. sound advise... Link to post Share on other sites More sharing options...
Cool Neutral Newbie March 10, 2002 Share March 10, 2002 yes... saw it on T.V once in australia advert. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 10, 2002 Author Share March 10, 2002 Thanks cool, will look into the floor panel and seats backing panel. Cheers! Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear March 11, 2002 Share March 11, 2002 Dun think insufelx would do the trick bro..... But what you can do is wind the window up to excess to the inner panels lor. You may have to cut the materials into smaller piece to be able to paste on the panels. Kinda tricky stuffs that you are trying man, door is not so easy as the floor. Link to post Share on other sites More sharing options...
Cool Neutral Newbie March 13, 2002 Share March 13, 2002 Hey Hey.. Forgot to tell you all the most important factor... how to prevent rust !!!! When I sound proof my car doors recently, this is what I did 1. Remove the door plastic compartment 2. Cover it with sponge sheet (1cm thick, got from Joo Chat Rd) 3. Cover the sponge with plastics sheets (got it from Bookshop) This is to prevent water getting into the sponge and cause rust 4. Spray anti-rust along the sponge parameters. This will prevent rust (at least) If you want to force the foam between the glass panel and door, remember to spray anti-rust cos foam traps water and when it rains, it will rust. You do not want to end up with a rusty door. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 13, 2002 Author Share March 13, 2002 Hey Cool, thanks for your invaluable tips! Will note them when doing up my friend's insulation. Link to post Share on other sites More sharing options...
Focusghia Neutral Newbie March 13, 2002 Share March 13, 2002 Hi, I'm new here Had a lil noise issue after installing Remus exhaust. While the exhaust is not loud outside the car, the exhaust note is too bassey within the interior. Wife's been griping car's been "Ah Beng"ed Toying w idea of sandwiching sound insulation between the heat shield & car body. But not sure of materials which can handle the heat from exhaust system. Any advise? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 13, 2002 Author Share March 13, 2002 U'd probably need an aluminized heat shield sheet. Something like the pic. Description here: http://www.designengineering.com/page22.html Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie March 13, 2002 Share March 13, 2002 Focusghia, Sound proofing is the best way to take out the noise from interior. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 13, 2002 Author Share March 13, 2002 btw, U driving a Focus with Remus exhaust? Fierce siah! Another way to insulate the exhaust sound from your cabin to to beef up your floor pan insulation. That'll involve removing the carpet and probably the seats as well. Link to post Share on other sites More sharing options...
Watzup Neutral Newbie March 14, 2002 Share March 14, 2002 How is the Remus exhaust sound? low or high pitch? Fully stainless steel? Link to post Share on other sites More sharing options...
Focusghia Neutral Newbie March 14, 2002 Share March 14, 2002 Thks. Checked out the link. Looks more like heat insulation product. There's already a stock AL heatshield in place. What I need is to insulate the noise close to source (muffler box) but hv to be heat resistant. Toying the idea of dropping by Hock Hin for high temp sound insulation sheets. They seem to hv some interesting products. Link to post Share on other sites More sharing options...
Focusghia Neutral Newbie March 14, 2002 Share March 14, 2002 Office carpets tiles? Not sure if there's enuff allowance to slip the carpet tile ~8mm T without bulging out floor pan carpet Link to post Share on other sites More sharing options...
Focusghia Neutral Newbie March 14, 2002 Share March 14, 2002 Twin rectangular pipes, stainless steel. Low growl - kinda wolf-like synch w Remus branding icon Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 14, 2002 Author Share March 14, 2002 I meant slipping some thin sound insulation material between your car carpet and the floor board. Office carpet tiles cannot put in car lah, too damn thick and also I don't think they can insulate sound well Link to post Share on other sites More sharing options...
Cool Neutral Newbie March 15, 2002 Share March 15, 2002 Done mine nicely... of course some areas does no permit you. cheers Link to post Share on other sites More sharing options...
Michel Neutral Newbie May 21, 2002 Share May 21, 2002 i was just thinking.... is it possible to insulate just only the area between the engine and the passenger compartment instead of the whole floorboard?? As least, it will reduce the noise by around say 30-40%(rough estimate & not scientifically proven), yah? ↡ Advertisement Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
Right side speakers no sound
Metal grinding sound on civic
