Methol Neutral Newbie February 8, 2007 Share February 8, 2007 Hi all Bro would like to check whether have any Bro have install this equipment(BRAKE BOASTER) in their car? Can describe the effect it have on the brake and car. All opinions are welcome btw is it worth to install it at $120??? ↡ Advertisement Link to post Share on other sites More sharing options...
Soleution Neutral Newbie February 8, 2007 Share February 8, 2007 got picture to show? Link to post Share on other sites More sharing options...
Keavze 1st Gear February 8, 2007 Share February 8, 2007 think refering to GNG aka vacuum tank that's connected between yr brake hose... it'll make yr brake feel more solid rather than spongy, also claimed to improve throttle response and fc. Link to post Share on other sites More sharing options...
Methol Neutral Newbie February 8, 2007 Author Share February 8, 2007 Is it worth to install in manual car? u install b4? Link to post Share on other sites More sharing options...
Ronnchee Clutched February 8, 2007 Share February 8, 2007 Comestic effect only, snake oil. Keep the $$ for petrol Link to post Share on other sites More sharing options...
Lukesky Neutral Newbie February 9, 2007 Share February 9, 2007 there's a safety aspect involved too cos if the brake booster fails or springs a leak due to lousy installation or maybe the hose punctured, then u're screwed cos yr brakes depends on vacuum to work and if vacuum is lost, u wont be able to brake much, so u might be saying hello to a tree very soon if the brake booster fails.. better think twice ah.. Link to post Share on other sites More sharing options...
Methol Neutral Newbie February 13, 2007 Author Share February 13, 2007 OIC so more disadvantage than advantage humm ok wun go ahead and install will do other things. Any other way to improve brake powers Bro? Can share? Link to post Share on other sites More sharing options...
Lukesky Neutral Newbie February 13, 2007 Share February 13, 2007 think one of the ways is change to steel braided brake hoses, or change to better brake pads. think most ex method is to change to 4 pot calipers. Link to post Share on other sites More sharing options...
Super4 Clutched February 13, 2007 Share February 13, 2007 Got money, anything is possible...so far no VOGS member installed 4 pot yet...my vios also not so hardcore for a 4 potter.... Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear February 14, 2007 Share February 14, 2007 on my previous ride, I have installed steel braided hose, and indeed, braking improves. You might want to consider that. Link to post Share on other sites More sharing options...
Methol Neutral Newbie February 14, 2007 Author Share February 14, 2007 How much will the cost be? PLus installation and where to do it? Anyworkshop to recommend? Link to post Share on other sites More sharing options...
Evildoer Neutral Newbie February 14, 2007 Share February 14, 2007 (edited) Hi all Bro would like to check whether have any Bro have install this equipment(BRAKE BOASTER) in their car? Can describe the effect it have on the brake and car. All opinions are welcome btw is it worth to install it at $120??? not interested le....btw got Brake Horse Power booster bo??? Edited February 14, 2007 by Evildoer Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear February 14, 2007 Share February 14, 2007 Brake booster I have not heard before. If its those GNG...forget it. Dun believe it and dun bother to try. You want to improve your brakes, you can try the following options. 1) Better brake pads 2) Steel braided hoses 3) Slotted brake rotors 4) Brake stopper 5) Better tyres. 6) Upgrade brakes system i) Change to a bigger brakes from same make (eg. Civic to Integra) ii) Change to bigger system (Endless Brakes, Brembo etc...) Brake stopper is a piece of specially design metal brace (for specific cars) that bolts to your brake master pump against your strut tower. This min flexing of the firewall during hard braking....so your brakes feel more positive. But you must be stomping on your brakes before you feel the effect. Link to post Share on other sites More sharing options...
Chromas 1st Gear February 14, 2007 Share February 14, 2007 There are proper products out there, eg. Brake Stopper kits from Cusco It attaches to your engine bay and pushes against the brake master pump to prevent it from moving forward while you apply pressure during braking. This reduces the sluggish feeling associated with some brakes and thus improves the overall braking of the car. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear February 14, 2007 Share February 14, 2007 mine was done in JB. the brand is Pro-RS. I believe there are whopshop here that carries this brand too. If I remember correctly, it was below $250. Link to post Share on other sites More sharing options...
Jermy Clutched February 14, 2007 Share February 14, 2007 another brand to recommend is APP. Heard that Pro-RS is made in msia rite? heard that the steel braided brake hoses actually only improves brake response. Coupled with a pair of good street brake pads, ur braking power should improve over stock. If u want, can change bigger rotors also. Best option is to change to a big brake kit la..but damage is a couple of Ks depending on the brand Link to post Share on other sites More sharing options...
Orixy 2nd Gear February 14, 2007 Share February 14, 2007 actually this brake cylinder stopper thingy is not difficult to DIY if u observe how it works. Just a solid bracket + bolts & nuts + a good drill shld get the DIY nicely done. Link to post Share on other sites More sharing options...
Chromas 1st Gear February 15, 2007 Share February 15, 2007 That's right... The Cusco ones cost around $250+ ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Brake squeak every morning
Handbrake Lever up, does the brake light comes on?
