DIY Active amp install help
Sturtles
Hi Guys, got from a friend here a twister 4x200W amplifier, and thinking of diying the install for an active setup on my current system of 1 x pioneer 9650 with 1 x pair of phd MF components.
I've never done this before, and I hope gurus here can contribute to the steps involved, ie, sequence and necessary hard presets like setting the HU to active mode etc, and equipment necessary to get the setup up and running, ie. fuse box, sets of cables and core size, etc.
I've posted a draft of my setup, and was wondering if a fuse box is necessary since the amp already has a 40A one.
Hope this thread can be helpful to those thinking of doing the same
Thank you
Microsoft PowerPoint - setup 2007.pdf
boss, u in a hurry or not? hahaha.. mit lancer i very familiar. can help you out, but u noe i now exam.
basically for lancer, good thing is there is a hole in the fire wall for u to run the power cable thru.
fuse box at the engine bay is a must.
cables, if u forsee urself doin further upgrades, my opinion, just run a 4 gauge.
if u tell urself this is ur die die last upgrade, 8 gauge can liao ( i doubt ur amp is 4x200 watts rms , prob 4x200peak)
if u can wait till ard may time, i definietly can help you out man.
but from ur power pt, its the wiring is correct, just add a fuse at the engine bay area to protect the cable (touch wood).
cheers
Edited by Headshok
Wow, bro, that's very fast!
I already have a fuse for my woofer wires, so won't that make too many fuse boxes?
This should be the last addition to my car, unless this amp really sounds bad lah.
So when's your exam over bro? Maybe we can go SLT together to look for cables for my DIY. Makan on me!
Hi, I have quite a nos of "unused" RCA cables in mint condition, including ready made and rolls of "monster cables"
Am prepare to sell it off cheaply if you are interested. Pls drop by my place to take a look.
Cheers
haha
i needa see how ur setup is wired man.
urs should be a fairly simple setup.
go bak and check whether u ahve the keys to remove ur HU. without this, will have hard time liao.. hahaha
exam over at beginnin of may sia. want to die.. hahaha.
drop me a message in may lah..
have fun!
cheers
No problem! I have the keys for the 9650, so taking the HU out should be fine.
Good luck for your papers man! I know how its like the exams are looming, too much time but too much to study
