Permanentheaddamage Neutral Newbie May 6, 2003 Share May 6, 2003 I thought Tye Soon was a wholesaler? Got any mechanic to recommend to change whole suspension? What is the estimated price? Thanks for your help! ↡ Advertisement Link to post Share on other sites More sharing options...
Cool Neutral Newbie May 6, 2003 Share May 6, 2003 Aiya.. I even walk in Tye Soon and buy parts... tell them you freelance mech, they will sell you. No idea on price and workshop. Link to post Share on other sites More sharing options...
Permanentheaddamage Neutral Newbie May 6, 2003 Share May 6, 2003 er... If I say I freelance mech, I guarantee you no one will believe! Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 6, 2003 Share May 6, 2003 i heard otein for certain models are too "hard", like for those EKs...it's very difficult to find a comfort level coilovers... Link to post Share on other sites More sharing options...
Typoerror Neutral Newbie May 6, 2003 Share May 6, 2003 thanks pal !! Link to post Share on other sites More sharing options...
Typoerror Neutral Newbie May 6, 2003 Share May 6, 2003 if you don't go on track often, spring + damper good enough......coilover is more suitable for track than for road use.... if thats the case, i better stick to spring + damper combo liao... Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie May 6, 2003 Share May 6, 2003 Was told once that need to do both at the same time, or do coilovers. Something to do with if springs and dampers are not properly matched, it'll reduce the life of one or the other. As for track vs road use, guess if it's racing grade, yah. There are street/racing ones right ? Some can even allow for adjustment of stiffness. Just put in a set of Tein Wagons for my Stream. Surprisingly, the ride doesn't feel too harsh, but cornering seems to have improved. Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 6, 2003 Share May 6, 2003 one more good lobang for you cool help me fix up apollo today and while on the way home... 1st stage vTEC kicks in twice at normal throttle i was kinda taken back Link to post Share on other sites More sharing options...
Typoerror Neutral Newbie May 6, 2003 Share May 6, 2003 huh...what is apollo???... Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 6, 2003 Share May 6, 2003 if i'm not wrong...the concept is similar to those popular brand like, fuel-max,etc...it is a device (a pair magnet?) that is fixed to the fuel line which suppose to...erghh...cant explain the actual reason also...do a search on apollo... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie May 6, 2003 Share May 6, 2003 if use the one for street one, of course it is comfortable but too expensive leh.... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie May 6, 2003 Share May 6, 2003 if you don't go on track often, spring + damper good enough......coilover is more suitable for track than for road use.... if thats the case, i better stick to spring + damper combo liao... cheaper option than coilover... Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie May 7, 2003 Share May 7, 2003 Need to shop around a bit... price can be few hundred different. Got mine at Fong Kim - much cheaper than McWell's quoted price. Cusco and HKS are even more pricy than Tein Link to post Share on other sites More sharing options...
Saaber Neutral Newbie May 7, 2003 Share May 7, 2003 try otein lah... Link to post Share on other sites More sharing options...
Gylgyl Neutral Newbie May 8, 2003 Author Share May 8, 2003 HI Saaber what is the average price of the Coil?? I just want a reasonable good coil... no need branded one or racing type... Anyway, do u think my old coil can still be used after i changed the suspension?? Any possibility the coil will be unusable or damaged?? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie May 8, 2003 Share May 8, 2003 Try Hotbits coilover....below $1k....I think Link to post Share on other sites More sharing options...
Luckcent 4th Gear May 8, 2003 Share May 8, 2003 For most cars, coil spring will not be damaged in any condition, it is the shocks that gave way. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie May 8, 2003 Share May 8, 2003 other than the Merwede Spring....sag big time... ↡ Advertisement Link to post Share on other sites More sharing options...
Front lower arm and suspension questions
Damaged ignition coil. consequences?
Is your car worth what it cost? [Shocking]
Noise from front engine area (suspension,maybe) when hit bump with left turn
TTC urethane cushion buffer
