Karebu 1st Gear June 10, 2007 Author Share June 10, 2007 okay thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Sotong_kia Neutral Newbie June 11, 2007 Share June 11, 2007 Fog on the outside means your aircon is damn cold ! And that humidity on the air outside is condensing onto your glass and even body. So just raise the thermostat on your aircon.. no need so cold. If you don't believe it is aircon, you try out : At night, turn your aircon, block all vents except one side (either driver or passenger side) and make it blow onto the window.. Less than 3 min, you will see a streak of condensation on THAT window only. Turn off the aircon, and wipe the water (on the outside) dry, wait a few seconds, you will still see it condensing. Why ? Cos the glass is still cold from the air-con. Just like after drinking ice water from a glass, you pour away the ice, quickly dry the glass. leave it for a while, still got water condensing. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear June 11, 2007 Share June 11, 2007 I think your temp is set too low. That is why it fogs up. Try lowering your temp and you should be alright...I drive in the early morning and I do not have this problem...my temp is set between 25 and 23 degree. Link to post Share on other sites More sharing options...
Apollo 1st Gear June 11, 2007 Share June 11, 2007 but.. isn't the condensation happening on the outside.. so what does the humidity on the inside have to do with this? (anyawy i did go open-air and using aircon on recycled mode - works.) condensation is usually on the side which has higher humidity. humidity = moisture in gaseous phase + temperature differential. it need not be something fr the car but it can b u, ur passengers, ur clothing, shoes, etc (source for moisture & heat). Link to post Share on other sites More sharing options...
Russ 1st Gear June 11, 2007 Share June 11, 2007 If the condensation is on the outside, it means the car is cold, meaning, before you parked the car, the air cond was set rather cold, so it is like a bottle out of a fridge. Try setting your air cond at a more reasonable level. You also save fuel by doing so and your car will also feel more powerful when the aircon compressor is cut off (it will cut in and out to manage the temp inside) On hot days, it does not happen as the RH outside is lower and the car air cond struggles to cope with the heat hence the temp differential between the car and the outside is small - also any condensation evaporates due to the heat outside. At nights, there is no radiation heat to take away this moisture and the air is more saturated with moisture. Oh, sometimes, even if the car air cond is off, you still get condensation due to dew forming when the temp drops and the air cannot hold that much moisture - that you cannot avoid. Link to post Share on other sites More sharing options...
Lightfinger Neutral Newbie June 11, 2007 Share June 11, 2007 try switching the air con to bring in fresh air rather than circulate.. Yup, it works. Link to post Share on other sites More sharing options...
Berneo Neutral Newbie June 11, 2007 Share June 11, 2007 Choose an air-con "blow setting" that is not blowing direct to your wind screen. This is reduce your cold air on glass plane and reduce condensation. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
Neighbour from the artic
Discussion on Gout problem
HDB season parking renewal problem
