Ruzhyo Clutched June 16, 2007 Share June 16, 2007 I wanna add a mid base speaker to my set up. But not sure if my current system can support. If can, any mid to recommand? No need super duper type, should be about the same range as my current set up. Hope the Gurus here can advice. My set up is as follows: Headset: Pioneer AVH-P6850DVD Processor: Pioneer DEQ-7650 Amp: Pioneer PRS-D410 Front speakers: Pioneer TS-C160R Center Speaker: Pioneer TS-CX7 Rear Speakers: Kenwood OEM speakers Satellite Speakers: Pioneer TS-STX99 Subwoofer: Pioneer TS-WX11A CD Changer: CDX-P1280 ↡ Advertisement Link to post Share on other sites More sharing options...
Jho0001 Neutral Newbie June 18, 2007 Share June 18, 2007 Hi, I'm considering installing the Pioneer TS-WX11A, appreciate your comments on it, good & bad. Thanks Link to post Share on other sites More sharing options...
Ruzhyo Clutched June 18, 2007 Author Share June 18, 2007 I guess depends on what car you drive and where u install it. I drive a tiny hatch and the only place to have it installed is against the rear seat firing against the hatch. It serves its purpose. But it would be better if you can have it installed it under the driver seat. Its no match for a proper sub. But if space and $$ is limited, its quite a good choice. The only complain I have is that its not tight. Link to post Share on other sites More sharing options...
Jho0001 Neutral Newbie June 18, 2007 Share June 18, 2007 Actually, mine will be installed in a Estima but intend to install it under the driver seat...I dont want anything big which will take up space or chest pounding...more into vocal and instrumental type music Link to post Share on other sites More sharing options...
Ruzhyo Clutched June 18, 2007 Author Share June 18, 2007 I listen to Jazz and it works well. If you have it under the seat you will feel the vibrations. Link to post Share on other sites More sharing options...
Jho0001 Neutral Newbie June 25, 2007 Share June 25, 2007 I'm looking at a setup quite similar to yours except that I will probably be installing the P7950. Is the sound coming from your setup, crisp and clear? I prefer to listed music which is vocal or instrumental. Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
EV Tyres
EV Tyres
Range Rover Evoque
Range Rover Evoque
How Much Range Does an Electric Car Lose Each Year?
Component speakers, no amp?
Gladen n Ground Zero speakers, are they related?
Right side speakers no sound
