Ieagle23 Neutral Newbie June 21, 2007 Share June 21, 2007 Hi guys, anyone here try cleaning the air-filter before, please see the attached picture (Open pod CAI), thinking of cleaning it by myself by running water & air dry (more than 40K liao). Will it damage the filter ? Appreciate all feedback. Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Boyboy 1st Gear June 21, 2007 Share June 21, 2007 (edited) 1st step take it out.. 2nd: unscrew the screws at both end, to allow u to remove the "shell" 3rd, running water, or use compressed air gun. i think water is easier to DIY at home n cleaner.. allow to drip dry 4th. reinstall n run engine to check/completely dry off the water. dun worry abt those few drops entering the engine. i assume u are using stainless steel mesh? if not my apologies... edit: no it will not damage the filter unless u drop it from 2nd storey or sth. just be careful when removing the shell and installing/uninstalling. these filters aren't made of glass and it won't rust cos it will be wet for awhile only, assuming u run ur engine as per step 4. or u sun it dry... Edited June 21, 2007 by Boyboy Link to post Share on other sites More sharing options...
Ieagle23 Neutral Newbie June 21, 2007 Author Share June 21, 2007 Hey..Thanks alot I will try it over this weekend ↡ Advertisement Link to post Share on other sites More sharing options...
Car carpet cleaning
Car carpet cleaning
Air Purifier Discussion - tips and info
DIY engine oil change
Recommendation for water filter
Dyson Zone, the real deal or has April fool's day come early?
Roomba - Vacuum Cleaning Robot (VCR)
Replacing fuel filter
