Madrock Neutral Newbie May 12, 2003 Share May 12, 2003 Hi... normally how long before we need to change our engine mounting? or how do we know if the mounting need to be changed? Coz so far two diff workshops has recommend me to change my engine mounting, but went back to BM, they said that nothing wrong with it and recommand that the mounting shld last around 6-7yrs?? Help pls becoz not cheap to change one. my car is 3 yrs old. Thanks alot! ↡ Advertisement Link to post Share on other sites More sharing options...
Saaber Neutral Newbie May 12, 2003 Share May 12, 2003 If agent says nothing wrong then leave it lor... Link to post Share on other sites More sharing options...
Yongwd 1st Gear May 12, 2003 Share May 12, 2003 excessive vibration during idling is a good indication that engine mounts are WEAK. Toyota original engine mounts design to last at least 150,000km or more under normal driving condition. I changed mine at 195,000km Link to post Share on other sites More sharing options...
Protoss38 Neutral Newbie May 12, 2003 Share May 12, 2003 I also having the same problem leh. Excessive vibration during idling..... My engine mounting need to be change? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie May 12, 2003 Share May 12, 2003 If your car is an auto try checking the mounting by getting a helper to listen for knocking sound when you shift into Drive or Reverse (with parking and foot brake on!) Usually the engine shifts slightly forward or backward when gear is engaged, if the mountings are shot then you'd hear the knocking sound quite obviously. Link to post Share on other sites More sharing options...
Madrock Neutral Newbie May 13, 2003 Author Share May 13, 2003 OIC...thanks alot... will try that! Link to post Share on other sites More sharing options...
Duadua2 Neutral Newbie May 13, 2003 Share May 13, 2003 how much u changed urs?n if manual,any signs? Link to post Share on other sites More sharing options...
Yongwd 1st Gear May 13, 2003 Share May 13, 2003 erm, I paid $250 for 4 mountings, DIY change them together with my mechanic. $30 for his labour Link to post Share on other sites More sharing options...
Vtim 3rd Gear May 13, 2003 Share May 13, 2003 don't think there's a need to change the mounting as your car is only 3yrs old. Unless you've have been in an accident involving the front part of the car, or like my previous car, launch up about 1meter into the air & 'slam dung' back onto the road ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Teana repair/parts
Teana repair/parts
