Pisces69 6th Gear July 31, 2007 Share July 31, 2007 pai seh to keep on asking ... which is more impt for a normal car driver, hp or troque? is it possible for a car to have high hp but low troque or a car to have low hp but high troque? if it is possible, what are the characteristics of a car with high hp but low troque and a car with low hp but high troque? thank you ================= More torque is better for stop/start driving like in the city as the torque is what gets u moving off from standstill. Less torque is ok if u do more cruising at a constant speed. ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 31, 2007 Share July 31, 2007 Rubber band stretching? I would love to hear it too.. ================= Maybe he means a "rubber"(condom). When u use it u have torque & HP going all at the same time. Link to post Share on other sites More sharing options...
Weichien Clutched August 2, 2007 Author Share August 2, 2007 will less torque have high consumption for fc? or more torque have better fc or lesser>? so nxt time change car can also consider the facts Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 2, 2007 Share August 2, 2007 It's hard to say. FC is determined by so many other things. Some cars have good low end torque but suffer at the high end. The engine design determines these things. There is always a trade-off. The best way to have good power all through the power-band is a bigger engine. Some cars get around it by turbo & supercharging but if not done properly, u still don't get what u want. Another thing is turbo & supercharging usually means higher FC & maintenance costs. Link to post Share on other sites More sharing options...
Rtth84 1st Gear August 2, 2007 Share August 2, 2007 forced induction makes the engine work less to produce the amount of torqur required for a certain amount of acceleration. so if you need to rev less, you will onsume less fuel. of course then you will need a light pressure turbo so that it spools at low RPMs Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 9, 2007 Share August 9, 2007 Actually forced induction allows the same size engine to burn more air & fuel to generate more power. This means higher FC but increased power. Link to post Share on other sites More sharing options...
Rtth84 1st Gear August 13, 2007 Share August 13, 2007 Forced induction these days are to enable the engine to meet emission standards and at the same time improve fuel efficiency Link to post Share on other sites More sharing options...
Viviobluerex Clutched August 13, 2007 Share August 13, 2007 torque in its most simplified form is a rotational force. Torque is the force that gets a car moving. Power is a measurement of how much work per unit of time that the torque is doing. Think of screwing in a screw. torque is the force you exert to turn the screwdriver. Power is the distance the screw has gone in in X amount of time. More torque is useful for faster acceleration or heaving loads that can be carried or pulled. Too much torque can be bad as the tyres may lose traction if the tyres arent good enough or it may break the transmission/drivetrain if they are not strong enough. Back to the screw... if you use a screwdriver with the wrong sized head you could "mushroom" the screw-head or if you use too much force after the screw is in, you may strip the thread. Hope the explanation helps Have not seen a more clearer explanation like yours for a long time. Good job. http://kcarclubsg1975.spaces.live.com/ ↡ Advertisement Link to post Share on other sites More sharing options...
Torque wrench hunt
Torque wrench hunt
RS Chip Tuning
RS Chip Tuning
This Video Cleverly Uses LEGO To Explain Torque And Horsepower
Automotive Glass: How does it differ from other types?
Is BHP and Torque really impt , which should we look at ?
Torque on the Move - Receive $140 worth of goodies! Vroom!
Local Car Magazine eg Torque
Torque On The Move tickets giveaway!
