Panalogic Neutral Newbie August 2, 2007 Share August 2, 2007 Dear all, My car doesn't use the full 4 litres of engine oil when i go for its servicing. As a result, i usually have abt 1 l or 800ml left. However, my concern is tht if i were to mix like shogun and idemitsu (both w30), is this adviseable? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Genie47 1st Gear August 2, 2007 Share August 2, 2007 Go ahead, the car doesn't know the difference and doesn't care. Link to post Share on other sites More sharing options...
Ares Neutral Newbie August 2, 2007 Share August 2, 2007 I have mixed and used engine oil before on many occassions. No harm done, go ahead. Link to post Share on other sites More sharing options...
Panalogic Neutral Newbie August 2, 2007 Author Share August 2, 2007 hi, wud u mind further elaborate on what u hv jus said? i don't understand wat u exactly mean :) thks Link to post Share on other sites More sharing options...
Panalogic Neutral Newbie August 2, 2007 Author Share August 2, 2007 i assume u mean diff oils with the same viscosity? Link to post Share on other sites More sharing options...
Genie47 1st Gear August 2, 2007 Share August 2, 2007 It doesn't matter much to the car when it comes to brands. It just wants oil to lubricate. Mix them and use them. Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 2, 2007 Share August 2, 2007 Dear all, My car doesn't use the full 4 litres of engine oil when i go for its servicing. As a result, i usually have abt 1 l or 800ml left. However, my concern is tht if i were to mix like shogun and idemitsu (both w30), is this adviseable? Thanks. Basically it's fine to mix any leftover oil from the same brand but not advisable for different brand oil. This may cause additives crash thus lower the boundary protection. Link to post Share on other sites More sharing options...
Panalogic Neutral Newbie August 3, 2007 Author Share August 3, 2007 Hi bro trex, as u can see now i have conflicting views. I have seen your previous posts b4 tht u r kinda into engine oils and stuff but can u provide some evidence to what u have jus said? ( really no offence here, i jus want to know more ) Thank you. Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 3, 2007 Share August 3, 2007 Basically engine oil formulation is pretty high tech stuffs which exact formulation is highly guarded. Oil company spends millions to formulate & test the additives package for solubility, anti-wear/anti-foam, oxidation and thermal stability. Thus any injection of foreign fluid with different base oil and additives package "might" upset the delicate balance of the host oil. Look at it this way, if you are using crappy cheapo engine oil and decided to added a quart of RL engine oil to bump up it's anti-wear additives level, no problem, how bad can it go. But if you decided to added 1 quart of leftover whatever oil to 3 quart of expensive RL oil, you are basically taking a risk that the foreign addition will not upset the fine balance of a very well build/tune engine oil. Logical. Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear August 3, 2007 Share August 3, 2007 Agree with Trex. Same to mix from same brand and same series of the same brand. I won't recomment different series of same brand. So for e.g., as long as it's Motul Power series, it is OK to mix 05w20 and 10w40. Link to post Share on other sites More sharing options...
Panalogic Neutral Newbie August 4, 2007 Author Share August 4, 2007 roger... thks what is ur opinion on shogun and idemitsu? I was recommended these oils as well as the TRD engine oil as they are said to enhance engine performance? Also when u mention RL u mean redline correct? Finally i am driving a 1.5 PI car from japan. Which oil will u recommend? thanks in advance :) Link to post Share on other sites More sharing options...
Natureg Neutral Newbie August 4, 2007 Share August 4, 2007 Bro too me is juz like cooking oil juz different brand that's why the price is different, as long as the oil can fried a chicken wing is good enough is up to different preference to choose the brand ....Most oil manufacurer will said their is the BEST I will still Go for Good & "Cheap" oil Im used to try different type of oil whenever i go for servicing every 2-3 mths as im always on the road......ive try the MOST Expensive....1L @ $24 as compare to the Cheapest Synthetic @ 1L @ $6 is a waste of $$$ to buy the expensive synth oil my car also cant go any faster still need to change @ 10K.....so nowaday i always go for the "Cheapest" Synthetic Oil still change @ 8-10K Well juz my 2 cents of opinion Link to post Share on other sites More sharing options...
Lexl Neutral Newbie August 4, 2007 Share August 4, 2007 If you are not particular about performance, then go ahead and mix...that's my pragmatic view. But if you are concerned, then stick with the same range - eg API SM or SL...different brands also use different types of base oils and some additive packages may not mix well with different types of base oils. Link to post Share on other sites More sharing options...
Panalogic Neutral Newbie August 4, 2007 Author Share August 4, 2007 wah 1l at 6... got so cheap one ah :) Link to post Share on other sites More sharing options...
Ultramega 1st Gear August 4, 2007 Share August 4, 2007 u said that because you sell cheap oil. pls la, we know who you are. u market CL brand. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
SCHNELL Engine Oil 5W40
