Gizmo Clutched August 28, 2007 Share August 28, 2007 Just take a look at any stream other than RSZ original rims one day. Look from the side at an angle. If the rims and tyre protude out a bit from fender(not flushed),than the offset is wrong.Consequences are ,rubbing the Fender at full load or hard cornering and doesn't look good. ↡ Advertisement Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear August 28, 2007 Share August 28, 2007 Damn, if that is the case, very hard to find replacement liao. Link to post Share on other sites More sharing options...
Tonylai Neutral Newbie August 30, 2007 Share August 30, 2007 Think the problem with Stream rims is the stock ones already pushed right out to almost edge of car. If you use offset 45, likely will protrude out a bit. But original rim is 6JJ. If you change to 6.5JJ or 7JJ, you'll have to use smaller offset anyway. Else may rub on springs or suspension... Link to post Share on other sites More sharing options...
Dankoo 4th Gear August 31, 2007 Share August 31, 2007 Just to check, for those that bought the Stream, 1. PI offers system with reverse cam (DVD), can I still have a LCD panel mounted on the middle? 2. Is there an option to have control buttons on the steering? Link to post Share on other sites More sharing options...
Tonylai Neutral Newbie August 31, 2007 Share August 31, 2007 Just to check, for those that bought the Stream, 1. PI offers system with reverse cam (DVD), can I still have a LCD panel mounted on the middle? >> Why do you want to mount another LCD panel? Reverse cam with DVD means already got a LCD screen already on the center console. No more space for another one. No need also. Unless you're talking about adding a roof mounted LCD for the back row to watch. If so, then sure can. Most audio shop can do for you. BTW, you may want to note that it is illegal to have LCD on center console playing movies when you drive. By right there should be a safety feature where the LCD will only display movie when hand/footbrake is engaged. But most PI do not connect that wire for you. Better check on that. Ignorance to TP is not an excuse. But, even with the handbrake wire connected, you can always request for a bypass switch to be installed. So you can choose to turn on/off the movie screen as you wish. 2. Is there an option to have control buttons on the steering? >> Control on steering is unlikely. Depend on what DVD unit the PI give you. Some brands / models have a steering wheel control module, but from PI likely is Taiwan/China brand. So likely no such module. Link to post Share on other sites More sharing options...
Dankoo 4th Gear August 31, 2007 Share August 31, 2007 For the LCD, I wanted it to be on the back row as I do not want to be able to see it and also at the front will not be very visible for ppl at the back. Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear August 31, 2007 Share August 31, 2007 Just take a look at any stream other than RSZ original rims one day. Look from the side at an angle. If the rims and tyre protude out a bit from fender(not flushed),than the offset is wrong.Consequences are ,rubbing the Fender at full load or hard cornering and doesn't look good. Saw on Stream X today, the rims and tyre really protude a bit from the fender. Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear August 31, 2007 Share August 31, 2007 Can I have some photo to illustrade all this thing about offset, JJ ? Link to post Share on other sites More sharing options...
Sputnik Neutral Newbie September 2, 2007 Share September 2, 2007 Most of the PI Streams I have seen seems to be on 17" low profile tires. I seriously doubt that they have been advised on the wrong offset. Yes it looks nice, but don't compromise on safety for cosmetic reasons. Also I feel that PIs should at least sound a warning to the owner 1st before slapping on the oversized rims. Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear September 3, 2007 Share September 3, 2007 If it is original RSZ rim, then it will be the correct size and offset. Link to post Share on other sites More sharing options...
Route88 2nd Gear September 3, 2007 Share September 3, 2007 Think the problem with Stream rims is the stock ones already pushed right out to almost edge of car. If you use offset 45, likely will protrude out a bit. But original rim is 6JJ. If you change to 6.5JJ or 7JJ, you'll have to use smaller offset anyway. Else may rub on springs or suspension... 6.5JJ still can use +55 , unless u can find these size for replica. As for 7JJ maybe +48 or +53 Link to post Share on other sites More sharing options...
Sputnik Neutral Newbie September 3, 2007 Share September 3, 2007 Yeap...the RSZ has got the correct offset for 17". I feel that it is rather worth it for the RSZ for the extras. Funny thing is that looking at the Stream forum, someone actually went and add the Mugen bodykit on a RSZ? Rich fella I guess. Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear September 3, 2007 Share September 3, 2007 Yah, RSZ is quite worth the money . Link to post Share on other sites More sharing options...
Dankoo 4th Gear September 4, 2007 Share September 4, 2007 Finally signed on the dotted line for RSZ yesterday.... Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear September 4, 2007 Share September 4, 2007 congratuts, can PM me the detail? Me still looking for one . ↡ Advertisement Link to post Share on other sites More sharing options...
hello
hello
hello
hello
Golden Village opens first all-laser cinema in Paya Lebar
Harddisk Diagnostic Test Software - Any good & free ones to recommend?
Driving in Europe
Driving in Europe
