Hlkh Clutched August 8, 2007 Share August 8, 2007 Hi all, normally at what mileage need to replace clutch? ↡ Advertisement Link to post Share on other sites More sharing options...
Devilution Neutral Newbie August 8, 2007 Share August 8, 2007 no specify 1.. if u feel ur gears cannot engage smoothly.. go have a check 1st den c if need to change den change it =X Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear August 8, 2007 Share August 8, 2007 Varies on too many factors. Whats wrong with yours??? Link to post Share on other sites More sharing options...
Hlkh Clutched August 8, 2007 Author Share August 8, 2007 engage gear is ok ... only some time when wanna remove shift from gear 1 got abit diffcult. any way to check if need to replace clutch ? Link to post Share on other sites More sharing options...
Hlkh Clutched August 8, 2007 Author Share August 8, 2007 I went to check for bad fc while test drive mech said my clutch finishing soon cause need to release higher and when pick up rpm move faster then the speed it should. Link to post Share on other sites More sharing options...
Gary84 1st Gear August 8, 2007 Share August 8, 2007 was it 60K?....tats what i heard Link to post Share on other sites More sharing options...
Mivec9 1st Gear August 8, 2007 Share August 8, 2007 i have changed mine...think around 75k or so. just changed clutch cable too recently Link to post Share on other sites More sharing options...
Hlkh Clutched August 8, 2007 Author Share August 8, 2007 i m not sure ... but my mileage now is 74000km Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear August 8, 2007 Share August 8, 2007 If the rpm is rising faster than the rising of speed than normal it means that the clutch is slipping liao which means time to change. Link to post Share on other sites More sharing options...
Hlkh Clutched August 9, 2007 Author Share August 9, 2007 can clutch free pay be adjusted? i hear 1 of my friend driving proton wira his clutch have not change for 9 yrs he say just adjust the clutch free play will do. Link to post Share on other sites More sharing options...
Sfrtuscani Neutral Newbie August 9, 2007 Share August 9, 2007 Hi all, normally at what mileage need to replace clutch? normal driving should last the life of ur car..... just change ur oil reglarly.... Link to post Share on other sites More sharing options...
Stivo Neutral Newbie August 9, 2007 Share August 9, 2007 free play can be adjusted ... as elfen stated regarding slipping else need not change... as for issue with trying to remove 1st gear... i will probably look at the gates of the box, synchros.. Link to post Share on other sites More sharing options...
Phoenix Neutral Newbie August 9, 2007 Share August 9, 2007 Pull handbrake, engage 3rd gear and slowly release clutch. If engine never die means clutch up the lorry. Link to post Share on other sites More sharing options...
Biting 1st Gear August 9, 2007 Share August 9, 2007 Should be able to last 150,000 to 200,000km Link to post Share on other sites More sharing options...
Rannrac Neutral Newbie August 9, 2007 Share August 9, 2007 it depends on car makes right? Usually for performance cars if you do play around with the car it will not last you that long right? Mine is around 47000km only and i think it's abt time to change. Link to post Share on other sites More sharing options...
Icetrap 2nd Gear August 9, 2007 Share August 9, 2007 Hi all, normally at what mileage need to replace clutch? You are asking a too general question. Different type of clutch may result in a different lifespan I believe when you free your clutch start to slip, it's time for you to change. If you throw your clutch everyday and do burnouts, you clutch gonna go in a few months dude. Link to post Share on other sites More sharing options...
Icetrap 2nd Gear August 9, 2007 Share August 9, 2007 I don't think this is a good way to check for clutch slip dude =X Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear August 9, 2007 Share August 9, 2007 can clutch free pay be adjusted?i hear 1 of my friend driving proton wira his clutch have not change for 9 yrs he say just adjust the clutch free play will do. You can adjust the pedal height but if the clutch is slipping it means time to change liao. Nothing else can be done abt it. ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
My huat ah mileage....
Change Disc Rotors
Change Disc Rotors
Need Advice on Self Storage
