Ken_au Neutral Newbie August 29, 2007 Share August 29, 2007 Hi ppl... Has anyone here encountered tis prob? I heard its because of the Windows XP Service Pack 2 bug... Anyone noes how to remedy tis prob? Im on the verge of throwing my Laptop out of the window cause I hav tried varies methods and ways but to no avail... Thanks... ↡ Advertisement Link to post Share on other sites More sharing options...
Melissa 1st Gear August 29, 2007 Share August 29, 2007 It happened to me sometimes too, but its bcos of my wireless network, i dun think its the windows XP SP2 bug... i will usually restart my laptop, and switch off & on my modem n router etc... Link to post Share on other sites More sharing options...
Apollo 1st Gear August 29, 2007 Share August 29, 2007 more likely is network problem try to ping the IP to test connection Link to post Share on other sites More sharing options...
Ken_au Neutral Newbie August 29, 2007 Author Share August 29, 2007 tried pinging the connection... and also tried renewing but still cant.. ip address now is the 169.***** I forgot wat but how do i assign a static ip address... my other com is werking fine with e netwerk but not my laptop... Link to post Share on other sites More sharing options...
Apollo 1st Gear August 29, 2007 Share August 29, 2007 i've neber used static IP. but u click Tool in the IE Menu and select Internet Option Selection Connection tab but Actually you should follow the instruction fr ur IP. Link to post Share on other sites More sharing options...
Multi 3rd Gear August 29, 2007 Share August 29, 2007 Have you tried "Repair" the network card. Right click on the network logo an select repair. Link to post Share on other sites More sharing options...
Serametin Neutral Newbie August 29, 2007 Share August 29, 2007 Hi ppl... Has anyone here encountered tis prob? I heard its because of the Windows XP Service Pack 2 bug... Anyone noes how to remedy tis prob? Im on the verge of throwing my Laptop out of the window cause I hav tried varies methods and ways but to no avail... Thanks... are u using a router or modem? try restart the router or modem i think it is nothing to do with the windows OS. if not, can also try to reboot the laptop. Link to post Share on other sites More sharing options...
Devilution Neutral Newbie August 29, 2007 Share August 29, 2007 shut down com restart modem den start com.. start modem.. if cannot.. go cmd type in /ipconfig /release 1st & ipconfig /renew Link to post Share on other sites More sharing options...
Passion 5th Gear August 29, 2007 Share August 29, 2007 bro,network card no problem.maybe just need to update the card.Maybe your wire use is wrong,com to router need crossover wire,not straight cable.unless your router has a smart port,if not do check the cable.maybe your DNS setting also,do set to default that which obtain automatically.If all this cannot,remove your firewall setting. Link to post Share on other sites More sharing options...
Turbine Neutral Newbie August 29, 2007 Share August 29, 2007 169.*.*.* , if this problem is in your office, more likely that it is setup with static IP instead. Get your company IT tech to do, they probably might monitor each individual IP's. Link to post Share on other sites More sharing options...
Zniper 2nd Gear August 29, 2007 Share August 29, 2007 guarateed plus chopped, it's not the bug... either prob wif ur connection or prob wif ur own network card... try pinging 127.0.0.1 to c whether ur own network card is working or not... if it replies, meaning ur connection got some issues... Link to post Share on other sites More sharing options...
Ken_au Neutral Newbie August 29, 2007 Author Share August 29, 2007 K thanks will try every suggestion... Link to post Share on other sites More sharing options...
Luckcent 4th Gear August 29, 2007 Share August 29, 2007 Hi ppl... Has anyone here encountered tis prob? I heard its because of the Windows XP Service Pack 2 bug... Anyone noes how to remedy tis prob? Im on the verge of throwing my Laptop out of the window cause I hav tried varies methods and ways but to no avail... Thanks... --------------------------------------------------------------------------------- let me know when you will throw your laptop...i want to collect it even from the rubbish bin. hahaha Cheers. Link to post Share on other sites More sharing options...
Slowmo Clutched August 29, 2007 Share August 29, 2007 I am good at putting laptops out of its misery, just give it to me... Link to post Share on other sites More sharing options...
Shull Turbocharged August 29, 2007 Share August 29, 2007 are you using LAN or wifi? Link to post Share on other sites More sharing options...
Suhong Neutral Newbie August 29, 2007 Share August 29, 2007 Just Do watever we say can lao Actually dun nd to restart com but restart ur router or modem If still cant call ur isp.... Just curious ur isp Singnet?? Link to post Share on other sites More sharing options...
DarkLord 1st Gear August 29, 2007 Share August 29, 2007 tried pinging the connection... and also tried renewing but still cant.. ip address now is the 169.***** I forgot wat but how do i assign a static ip address... my other com is werking fine with e netwerk but not my laptop... Are you using Singtel BB? Link to post Share on other sites More sharing options...
Ken_au Neutral Newbie August 29, 2007 Author Share August 29, 2007 Yup using singtel bb with the 2wire 2700HG modem... Tried calling singtel like 4 times.. 4 diff ppl tried to help me.. all cannot help.. push blame to moden fault.. Sianz... ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Rich man's problem, owner suing Aston Martin because engine too loud
Cars We Don't Get to Drive in Singapore
Dealer re-sell problem car
Mini JCW GP Roll Over Shortly After Owner Takes Delivery
