Chiqinhan 1st Gear October 12, 2007 Share October 12, 2007 any idea hw much does the installation charge to install them including cables? thks ↡ Advertisement Link to post Share on other sites More sharing options...
Bearbear1494 Clutched October 12, 2007 Share October 12, 2007 From my experience in the past was S$20 for front & rear speakers install, provided only need to drill new mounting holes. If require MDF spacers, then additional charge. Install 2 amps including normal grade RCA, speaker & power cables around S$80-S$100, depending on the length of the cables & amount of fixtures that need to be removed for laying of the cabling. Sub if just normal box type, usually FOC. If not just pay for the length of speaker cable required. If need box, then ready-made box is around S$50. If custom enclosure, then you'd have to check with them. ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel Spacer Installation DIY
Washing machine front loading
Component speakers, no amp?
Rear seat passenger : Do they belt up?
Is it illegal to fetch passengers at the back of a Suzuki Every?
