Aimnfire 4th Gear October 18, 2007 Share October 18, 2007 guys roughly how much is the cost to install new brake pads? i dont fancy anything as long it do the work please advise so that i dont kena chop my brake give out sound already i think brake pad due to change (74k already) thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear October 18, 2007 Share October 18, 2007 Get factory or OEM from a reputable brand (e.g. mintex, TRW, etc and you'll be fine). Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie October 18, 2007 Share October 18, 2007 what car are you driving? original brake pads, or oem brake pads? roughly about 80-150 inclusive of labour Link to post Share on other sites More sharing options...
Aimnfire 4th Gear October 18, 2007 Author Share October 18, 2007 oh ok thanks Link to post Share on other sites More sharing options...
Aimnfire 4th Gear October 18, 2007 Author Share October 18, 2007 kia cerato not sure which one to choose but most probably the cheaper ones but if price different is only few bucks might as well i go for a better type so between 80-150....ok thanks i will take note of the pricing thanks Link to post Share on other sites More sharing options...
Accord Clutched October 19, 2007 Share October 19, 2007 'Nissinbo' Made in Japan..reasonably cheap n good...no regrets Link to post Share on other sites More sharing options...
Aimnfire 4th Gear October 19, 2007 Author Share October 19, 2007 ahhh ok thanks but how about if i just bought the brakepad and went JB to install it? in this case roughly how much is the cost range of buying just the brakepad? are brakepad can fit most cars? Link to post Share on other sites More sharing options...
Accord Clutched October 19, 2007 Share October 19, 2007 Some can be install on a few model of same made but mostly can't, price not very x but definately better then stock from my own experiences. Should not be any problem fixing anywhere lor. Link to post Share on other sites More sharing options...
Aimnfire 4th Gear October 19, 2007 Author Share October 19, 2007 ok but forgot to ask where can i get this and roughly how much? thank you Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged October 19, 2007 Share October 19, 2007 Bosch brakepads are relatively inexpensive. if i'm not wrong, it cost less than $30 for 1 pair. u try call bosch singapore cust service hotline to set the brakepad part number meant for yr car, n ask them to refer a few distributor to u. installation is from $20-$30 just to instal the pad. iadvice that u also bleed yr brake fluid n sevice yr rear drum brakes. servicing of brakes inclusive of new brake fluid cost $30-$45. I go to a workshop in Esso station along Lavender street, opps singapore casket. honest mechanic,reliable job. Link to post Share on other sites More sharing options...
Accord Clutched October 19, 2007 Share October 19, 2007 you may want to check with Tye Soon, I bought it there. contact no:65697065 Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged October 19, 2007 Share October 19, 2007 diff brakepads for diff cars.. dun set wtong size. if u wanna use back original kia pads, can go Song Yi at veerasamy road, they r korean car stockist. call raymond at 62973700. I think original kia brakepads is aroung $50+-60. he can also recommend a ws specialized in kia car. I m using Icer brakepads @ $65. braking power same as original but tons of brake dust, cannot make it. try bosch lor.. cheap at less than $30, n bosch is reliable Oem maker for car parts. Link to post Share on other sites More sharing options...
Carlover76 Neutral Newbie October 19, 2007 Share October 19, 2007 Brother, if you are looking at better brakes compared to the stock brake pad, I will suggest you go for Mintex Performance Brake Pads which I am using for my ride too, it will brake a lot better than stock brake pads. Price not expensive, you can check out Kia Club for the Group Buy. Link to post Share on other sites More sharing options...
Westender Neutral Newbie October 19, 2007 Share October 19, 2007 Regarding brake dust, just wondering. Why does some cars(especially euro cars) have so much brake dust? Do they wear out faster? Link to post Share on other sites More sharing options...
Aimnfire 4th Gear October 19, 2007 Author Share October 19, 2007 hmmm thanks for the idea btw...my rear also using disc not drum brake ok i will check it out with bosch thanks Link to post Share on other sites More sharing options...
Aimnfire 4th Gear October 19, 2007 Author Share October 19, 2007 thanks for the contact Link to post Share on other sites More sharing options...
Aimnfire 4th Gear October 19, 2007 Author Share October 19, 2007 i dont care abt the brake dust as long it give decent braking;p futhermore kia original brake pad is more expensive than bosch will look into bosch thanks Link to post Share on other sites More sharing options...
Aimnfire 4th Gear October 19, 2007 Author Share October 19, 2007 ait i saw somebody selling mintex pad at kia forum but i tot that is for picanto? ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Brake squeak every morning
Handbrake Lever up, does the brake light comes on?
