Venco25 Neutral Newbie October 31, 2007 Share October 31, 2007 Hi all, does anyone know what bulbs the EP80 use? eg H4, HB4? TIA ↡ Advertisement Link to post Share on other sites More sharing options...
Kyojin 1st Gear October 31, 2007 Share October 31, 2007 Dipped beam (normal) = H4 High beam = H4 Parking lights = W5W Front/rear indicators = P21W Link to post Share on other sites More sharing options...
So_nice 6th Gear October 31, 2007 Share October 31, 2007 which philips bulb is LTA compliant? i mean those slightly white-ish ones. Link to post Share on other sites More sharing options...
Kyojin 1st Gear October 31, 2007 Share October 31, 2007 shouldn't have any problems la... for halogens. but it causes irritation to driver in front, not to mention damn ah-beng ( sorry StarletGT!) anyway, i'm probably gonna get LED W5W to replace my parking lights, since they don't run so hot and so it won't melt my silicone. Link to post Share on other sites More sharing options...
Venco25 Neutral Newbie October 31, 2007 Author Share October 31, 2007 Thank you for your prompt response & help! Link to post Share on other sites More sharing options...
So_nice 6th Gear October 31, 2007 Share October 31, 2007 wat blubs are u using and are they lta compliant? Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie November 1, 2007 Share November 1, 2007 ehh... what is w5w and P21w? the position/indicator/small light (whatever it is called) is not T10 meh? Link to post Share on other sites More sharing options...
Kyojin 1st Gear November 1, 2007 Share November 1, 2007 T10 = W5W Link to post Share on other sites More sharing options...
Kyojin 1st Gear November 1, 2007 Share November 1, 2007 Replacement bulbs must be of a design recommended by the vehicle manufacturer. Using a higher wattage bulb may increase the risk of fire because of a greater current being drawn to power these lamps. Therefore, these types of bulbs are not allowed. from: http://www.onemotoring.com.sg/publish/onem...ml#MainPar_0036 on the same note: http://www.onemotoring.com.sg/publish/onem...ml#MainPar_0045 Link to post Share on other sites More sharing options...
So_nice 6th Gear November 1, 2007 Share November 1, 2007 tat means so long as same voltage its okay? Link to post Share on other sites More sharing options...
Kyojin 1st Gear November 1, 2007 Share November 1, 2007 you mean same wattage (power rating)? voltage is standard 12V. Link to post Share on other sites More sharing options...
Accord Clutched November 23, 2007 Share November 23, 2007 Try BlueVision or XtremePower H4. Ihave spare H4 BlueVision, you may PM me if you need that,:) ↡ Advertisement Link to post Share on other sites More sharing options...
Quad Light Bulb Size
New Study Explores Connection Between The Size Of Your Manhood And Sports Cars
Tire size not available in Singapore, how?
Giving away EP80 GT Grille
Bulb replacement : help needed
A new tire size calculator
Cost of changing headlamp bulb, foglight bulb
Front and rear different tire size
