Funkyjazz Neutral Newbie November 27, 2007 Author Share November 27, 2007 I have not start any mod yet, still stock.... Before ICE, acceralation not sluggish leh! ↡ Advertisement Link to post Share on other sites More sharing options...
Funkyjazz Neutral Newbie November 27, 2007 Author Share November 27, 2007 Hi Vblaster, When you said ICE draws power from alternator, do you mean the amp cable is connected to alternator? Link to post Share on other sites More sharing options...
Donraj Neutral Newbie November 27, 2007 Share November 27, 2007 Install a capacitor to solve your problem. Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear November 27, 2007 Share November 27, 2007 A typical ICE with amps will drain the battery in no time. In reality, even though the connection is from the battery, the alternator is maintaining the current. Unless your ICE is causing your voltage to peak and drop significantly, thereby affecting ignition of the spark plugs timing, you should not feel any difference in engine performance. Link to post Share on other sites More sharing options...
Headshok 1st Gear November 27, 2007 Share November 27, 2007 yo man to put in simple terms the battery is to start the car. after that, the electrical needs of the car is supported by the alternator if u look at ur battery connections, there is a wire from the alternator. the alternator charges the battery. so in an indirect way, the amp power cable is " connected" to the alternator since the amp lug is connected. can picture. anyway, if u wanna try, go invest in some grouding,it might help and is relatively cheap to do. addin a caps wont help. cheers Link to post Share on other sites More sharing options...
Funkyjazz Neutral Newbie November 27, 2007 Author Share November 27, 2007 JUst now I ask my installer to remove all the ICE cable connection to battery. Vola! My car feel lighter, performance has improve but still not as responsive as before. Really don't know how to explain, never happen to my previous ride??? Link to post Share on other sites More sharing options...
Dunno Neutral Newbie November 27, 2007 Share November 27, 2007 Do grounding and voltage stabilizer. Should help to give a more responsive ride. Want lagi better response, lup in a SCC with CAI. Link to post Share on other sites More sharing options...
Wankie Clutched November 27, 2007 Share November 27, 2007 your amps like 10000 watts each? could be something else lah, better get it checked... Link to post Share on other sites More sharing options...
Kb27 Supersonic November 27, 2007 Share November 27, 2007 I think your battery cannot cope with the additional power drain from the two amps. The battery is also needed to operate the ecu and many sensors. A weak battery can affect performance of the car. It could be the battery is not being charged properly or it is dying already. If possible, you might want to try with a new battery or borrow one first. Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear November 27, 2007 Share November 27, 2007 Refer to past posts - it is not likely to be the battery. Link to post Share on other sites More sharing options...
A881010 Neutral Newbie November 27, 2007 Share November 27, 2007 Dear all, need some feedback... I notice a slight drop in car performance(pick up) after installing 2 nos. of amps in my new car. Does anybody experience that? probably your amps total wattage exceed your car batt ampere. adviseable to add a capacitor between your amps to batt via fuse block. Link to post Share on other sites More sharing options...
Psfong Clutched November 28, 2007 Share November 28, 2007 Hmmm, its possible that the installer reset the ECU when installing the ICE... Link to post Share on other sites More sharing options...
Tazster_t Neutral Newbie November 28, 2007 Share November 28, 2007 Dear all, need some feedback... I notice a slight drop in car performance(pick up) after installing 2 nos. of amps in my new car. Does anybody experience that? i do experience some drop in performance when my stereo is on.. guess the car needs to channel some energy to keep the bass going... hahaha Link to post Share on other sites More sharing options...
Ivan0507 Neutral Newbie November 28, 2007 Share November 28, 2007 i think maybe one of your amps is fxxk up. your system is not so hungry .i am running 2 amps in my system ,one amp is running at 1ohm around 1400w and the othersamp also running around 800w ,i am using stock battery and already two years+ ,so far so good ,never got this problem before. but my friend did experience on this with a faulty amp .just overnite after installing the amp ,the battery goes flat. ↡ Advertisement Link to post Share on other sites More sharing options...
Music Concerts
Music Concerts
Why Singapore does not support renewable energy and EV?
RS Chip Tuning
RS Chip Tuning
No basis for employers to cut pay if flexi-work does not affect productivity: Gan Siow Huang
2023 Mercedes-AMG C63 S E Performance
Kra canal affect Singapore Port
Consolidation of useless modification (Performance parts)
