Silklee 3rd Gear March 18, 2008 Share March 18, 2008 My civic comes with Vkool installed. Anyway I think there is an air bubble or water bubble on the windscreen on the inside of my car. It is not a scratch or chip in the glass as it feels smooth to touch and I cant clean it off. Is there anything I can do about it? The vkool brochure says any water bubbles will disappear in 4 to 10 weeks. I have my car for about 4 weeks now. Anyone has any experience on this? Anything I should do? ↡ Advertisement Link to post Share on other sites More sharing options...
Silklee 3rd Gear March 18, 2008 Author Share March 18, 2008 Forgot to add. It is irritating me quite a bit because it is right in front of my sitting position. Once I see it, I cannot Link to post Share on other sites More sharing options...
Boyboy 1st Gear March 18, 2008 Share March 18, 2008 (edited) i heard that can use a VERY FINE needle to poke a small hole in the bubble, then massage it. i think they will do that for u FOC if u return to them EDIT: if u diy salah i accept no flaming hor advise u to see ur installer Edited March 18, 2008 by Boyboy Link to post Share on other sites More sharing options...
Perrier 1st Gear March 18, 2008 Share March 18, 2008 (edited) You need to park your car under the hot sun. I had lots of bubbles after installation, I was told to 'sun' the car. "luckily", my company carpark are those open-air ones so the bubbles disappeared gradually after 3-4 weeks. Relax. Just park your car on top of the MSCP on weekends. Edited March 18, 2008 by Perrier Link to post Share on other sites More sharing options...
Silklee 3rd Gear March 18, 2008 Author Share March 18, 2008 I park in the open air when at work. Still there after 1 very hot day out in the open le. Maybe need more sun? Is it reasonable to assume that it is the fault of the vkool because 1. it is smooth to touch 2. I cant clean it off 3. It is on the inside of the car (seems so to me because when I look from the outside, it seems Link to post Share on other sites More sharing options...
Perrier 1st Gear March 18, 2008 Share March 18, 2008 The bubbles will slowly reduce in size and eventually disappear. You can mark out certain bubbles and monitor the size. These bubbles is trapped within the solar film, cannot rub off one. Initially I thought it was bad installation, called them and was told to wait a while longer. After a while I also too lazy yo monitor but now all bubbles are gone. There was a thread somewhere concerning bad installation of Vkool not too long ago. Car also from Kah motor. Do a search, you should find it. Link to post Share on other sites More sharing options...
Dafansu Turbocharged March 18, 2008 Share March 18, 2008 4 weeks is a long time already, u can go back for them to rectify Link to post Share on other sites More sharing options...
Silklee 3rd Gear March 19, 2008 Author Share March 19, 2008 Called Vkool. They offered a replacement with little questions asked. ↡ Advertisement Link to post Share on other sites More sharing options...
Family of three electrocuted to death at Taman Jurong
