Nkotb 1st Gear March 23, 2008 Share March 23, 2008 when i parked my car and get out of my seat, there is a loud creaking noise coming from the back of the car.. Is it the suspension spoil liao ?? ↡ Advertisement Link to post Share on other sites More sharing options...
Markxfan Neutral Newbie March 23, 2008 Share March 23, 2008 why not send to AD? Link to post Share on other sites More sharing options...
Enrique Neutral Newbie March 23, 2008 Share March 23, 2008 (edited) ya lor y not send to AD? or mayb can send email to Overboost and ask him to help u. Otherwise u gonna get stupid replies like "it's like that one" again. Edited March 23, 2008 by Enrique Link to post Share on other sites More sharing options...
Nkotb 1st Gear March 23, 2008 Author Share March 23, 2008 hahaha... i got loads of epsiode with AD wor... going to call them on monday.. paisei, didnt make it for the meetup.. just back from bintan and was very tired.. Link to post Share on other sites More sharing options...
Enrique Neutral Newbie March 23, 2008 Share March 23, 2008 (edited) loads of episodes. well, since Overboost is here, can consult him here or send to his email lor. betta dun start trouble, otherwise kena labelled as flame starter and worse of all kena legal action. Can see that he is very prompt in here. Edited March 23, 2008 by Enrique Link to post Share on other sites More sharing options...
Application9999 Clutched March 23, 2008 Share March 23, 2008 am quite sure the sound come from the rear brake disc...try to pull your hand brake higher and tighter...do u still hear the sound? Link to post Share on other sites More sharing options...
Bunny21 Neutral Newbie March 23, 2008 Share March 23, 2008 Link to post Share on other sites More sharing options...
Enrique Neutral Newbie March 23, 2008 Share March 23, 2008 y must pull the hand brake higher and tighter? is that normal for Fiat cars? if it ain't normal, is there any problem with the car? Link to post Share on other sites More sharing options...
Application9999 Clutched March 24, 2008 Share March 24, 2008 Not for particular car...it could be the rear disc brake pad rubbing against the breake disc..that's what I used to encounter in my opel previously...try it...no harm mah... Link to post Share on other sites More sharing options...
Enrique Neutral Newbie March 24, 2008 Share March 24, 2008 if that is the case, i would suggest NKOTB to go back to AD and rectify the brake pad rubbing against the brake disc problem instead of pulling the handbrake higher and tighter. Link to post Share on other sites More sharing options...
Contax 1st Gear March 24, 2008 Share March 24, 2008 when i parked my car and get out of my seat, there is a loud creaking noise coming from the back of the car.. Is it the suspension spoil liao ?? mine too , but am not to concern . Link to post Share on other sites More sharing options...
Nkotb 1st Gear March 24, 2008 Author Share March 24, 2008 guess its normal then ... i tried pulling the handbrake higher and the sound is not so obvious... thanks for the tip... when will the new site be up ?? Link to post Share on other sites More sharing options...
Timmz Neutral Newbie March 24, 2008 Share March 24, 2008 mine car has the same. wen u get out of the car, the suspension lifts off, this rise in height will cause the wheel/tyre to turn. the tyre cannot turn freely coz the handbrake is on, however if the handbrake is not tight enough, the wheel will still force turn due to the released spring energy. The squeek is the friction sound of the rear brake pads. if you follow the test stated by the earilier post to have the handbrake very tight. The wheel will not be able to turn, hence no sound of the brakes gripping! This just proved taht ot required very little braking power to keep the car stationary. Link to post Share on other sites More sharing options...
Enrique Neutral Newbie March 24, 2008 Share March 24, 2008 if this is the case, then adjust the handbrake so that u dun haf to pull higher. Link to post Share on other sites More sharing options...
Nkotb 1st Gear March 24, 2008 Author Share March 24, 2008 go where to tighten ?? i just remembered 2 days back, my car rolled back even with the handbrake engaged..thats about the same time that i hear the sound.. to go AC or AD ?? Link to post Share on other sites More sharing options...
Enrique Neutral Newbie March 24, 2008 Share March 24, 2008 (edited) of cos go back to AD. if u engaged ur handbrake and it still rolls, then definitely must adjust the handbrake. this compromise safety becos if u park on a slope, that's it man. I'm sure Overboost can help u arrange to adjust the handbrake. Dun think this is unreasonable rite? Edited March 24, 2008 by Enrique Link to post Share on other sites More sharing options...
Application9999 Clutched March 24, 2008 Share March 24, 2008 no problem..glad my tips helps...this rear brake thingy is quite normal.. Link to post Share on other sites More sharing options...
Contax 1st Gear March 25, 2008 Share March 25, 2008 like what bro on top have mention go to the AD if time permit if you're pulling your hand brake too high up already , get it adjusted asap. ↡ Advertisement Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
Right side speakers no sound
Metal grinding sound on civic
