Skoder Neutral Newbie April 3, 2008 Share April 3, 2008 Hi, So we know that when u change your stock wheel to a new one with different size, teh odo and speedo will be inaccurate... Was running 205/65/15, now running 215/45/17 WHEN 205/50/17 would be closer, but my backside itchy... Was on 18.5kg with rims and tire, total 74kg. Now on 16.2kg with rims @7.2 and LS2000 @9kg bringing a total of 64.8kg A loss of 9.2kg off the unsprung weight. But my FC went up... /cry So now my speedo is about 10 km off/higher against my GPS (according to formula, its suppose to be 3.4% higher based on the differnce, but its aint so for my case). With this, my odo is affected/screwed and there goes my calculation for my FC... Anyone know if theres a way/programme to let the ECU learn its new rolling radius? ↡ Advertisement Link to post Share on other sites More sharing options...
Akula Turbocharged April 3, 2008 Share April 3, 2008 Cant help you much on the ECU part but 2 near identical sizes are 215/50R17 ( neg. diff ) and 235/45R17 ( very slight diff ), 205/50R17 still a little under sized . Perhaps a better option is to trade in your tires and get these 2 sizes, rather than messing around the ECU. Link to post Share on other sites More sharing options...
Skoder Neutral Newbie April 3, 2008 Author Share April 3, 2008 Actually, i change to 215/50 profile on F1 eagle GS-D3 (kim chi version).... but not used to the high sidewalls, when going around bends makes me feel dizzy... too used to 45 profile for a long long time liao....so change to 45 lor... u mean the ecu can be adjusted with certain settings? Link to post Share on other sites More sharing options...
Akula Turbocharged April 4, 2008 Share April 4, 2008 Dun know much abt ECU and electronics, so cant comment. But you came from 205/65R15 to 17 inches and 50 series sidewall makes you dizzy. Think its easier/simpler to change to 235/45R17 rather then try to mess around with the ECU. Also a reset/adjustment will most prob cost you money, which you will need to weigh against the cost of trading in your current tires for the 235/45R17s. ↡ Advertisement Link to post Share on other sites More sharing options...
Mechanised parking systems at HDB estate rolling out in 2015
Rolling in the Deep (Cover)
Head on into a rolling object
Radius International Hotel KL
Upsizing rolling diameter
Fan belts near alternator got rolling sound
Michelin Primacy LC-lower rolling resistance=poorer grip?
Volvo S40 Turning Radius
