Acerchan2002 Clutched June 1, 2008 Share June 1, 2008 Currently driving SFA getz,fuel tank 45l,light-footed,able to go 350km onli,FC=7.8km/l....damn terrible,drinks like hell,any bros or sis can give me advice?Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Iziz Clutched June 1, 2008 Share June 1, 2008 Usual tips: 1) Dun carry excessive weight 2) Over-inflate tyres by abt 10% 3) Dun speed (wind resistance/aerodynamics more optimal at lower speeds) 4) Parts due for change? Not working efficiently hence the higher FC Hope this helps. Link to post Share on other sites More sharing options...
Lawr3nce Neutral Newbie June 1, 2008 Share June 1, 2008 Try checking the following: Oil filter Engine oil Air Filter ---------------- Next will be trottle body intake manifold ---------------- if everything is in working condition change engine oil brand.. sometimes it affects. my 1.4getz getting around 11-12 so i dun think urs will be so drastic deprovement. Link to post Share on other sites More sharing options...
Shox87 4th Gear June 1, 2008 Share June 1, 2008 that's weird? any leaks from ur fuel tank? getz FC at 7.8km/l, thats shocking! Link to post Share on other sites More sharing options...
Route88 2nd Gear June 1, 2008 Share June 1, 2008 change air filter ,clean T.body, tyre correct size si boh,go for 20w or 30w oil. Reset ECU Link to post Share on other sites More sharing options...
Thrillman Neutral Newbie June 1, 2008 Share June 1, 2008 Worst then a 2.4litres , think need to change engine liao. SAD Link to post Share on other sites More sharing options...
Sky8807 1st Gear June 1, 2008 Share June 1, 2008 Currently driving SFA getz,fuel tank 45l,light-footed,able to go 350km onli,FC=7.8km/l....damn terrible,drinks like hell,any bros or sis can give me advice?Thanks What is your best FC so far? Link to post Share on other sites More sharing options...
Fatfatgetz Neutral Newbie June 1, 2008 Share June 1, 2008 i used to drive a SFA getz too same FC as u get in the end i changed my ride no matter how i change what type of air filter or what type of engine oil add VS or change to a better spark plug it still get the same fc u got two choice either u swap ur engine or like me change the ride Link to post Share on other sites More sharing options...
Bearbear1494 Clutched June 1, 2008 Share June 1, 2008 Check and replace if necessary ; - Air Filter - Spark plugs (ensure correct heat range) - Engine Oil - Oil Filter - Throttle body - Fuel Filter - Tire pressure Is the engine feeling lethargic with noticeable loss of power? If so, that may be the main cause of the high FC. Get a mech to do a thorough check. The above checklist is what I usually go through when my FC suddenly increases by a big margin. Normally, a change of air filter, oil filter & oil, and new plugs will solve it. Link to post Share on other sites More sharing options...
Booboon 1st Gear June 1, 2008 Share June 1, 2008 seems like getz is a lemon, fuel guzzler Link to post Share on other sites More sharing options...
Familymanz 3rd Gear June 1, 2008 Share June 1, 2008 engine overhaul Link to post Share on other sites More sharing options...
Bearbear1494 Clutched June 1, 2008 Share June 1, 2008 Not really. Have a few friends who own Getz, from 1.1 to 1.6, all report that they're a little FC heavy, but still manageable. At 7.8km/l like the TS, one might as well be driving a Colt Version R, or perhaps a WRX. At least those owners get greater performance & possibly more driving fun out of the same amount of petrol. Link to post Share on other sites More sharing options...
Quantum 5th Gear June 1, 2008 Share June 1, 2008 Currently driving SFA getz,fuel tank 45l,light-footed,able to go 350km onli,FC=7.8km/l....damn terrible,drinks like hell,any bros or sis can give me advice?Thanks I believe you are using wrong F.C calculation should not be 350/45 lah, are you sure before every filling you drain dry your fuel tank[laugh] if you based on fuel empty light, normal the light on when 10L remaining, so your FC should be 350/35=10km/l Link to post Share on other sites More sharing options...
Lightfinger Neutral Newbie June 1, 2008 Share June 1, 2008 I'm driving a 1.3A Getz, it's ok, getting about 11.5-12km/l (60% highway, 40% city). Most impt is, control right foot + driving style. I have friends who floored the pedal for the Getz too, and can 'achieve' the 7.x to 8km/l mentioned... Link to post Share on other sites More sharing options...
Newkid 2nd Gear June 1, 2008 Share June 1, 2008 As far as I know, Hyundai cars tend to be fuel rich, in terms of air-fuel ratio. can afford to run slightly leaner, which shd save some petrol, but needs to re-tune the ECU, and affects warranty. this is my experience with Hyundai Coupe 1.6M from 2000 to 2004. Link to post Share on other sites More sharing options...
Spurman Supercharged June 1, 2008 Share June 1, 2008 issit cheap to retune the ecu? i drive a 1.1m, and used to get 14.5km/ltr, now onie get 13km/ltr Link to post Share on other sites More sharing options...
Archon 2nd Gear June 1, 2008 Share June 1, 2008 (edited) my 1.2l punto is giving me abt 14- 17km/l Edited June 1, 2008 by Archon Link to post Share on other sites More sharing options...
Valtino Neutral Newbie June 1, 2008 Share June 1, 2008 im driving a getz 1.6, currently done my extractor and muffler. After all this mods my consumption was 8 - 9 km/l even with light foot but heavy foot about 6km/l ↡ Advertisement Link to post Share on other sites More sharing options...
Are You A Big Spender For A High End Bed Mattress?
MyResponder app to call SCDF
Help with STA report remarks
ACS boy dies during high adventure course
