Tohto Hypersonic November 17, 2008 Share November 17, 2008 Tried yesterday but after a while the "GPS not fixed" sign go off but i am still not connected???? Hi Bro, Did you solved the above problem? I got my Omnia phone yesterday. When try connect to GPS, also always getting a " GPS not fixed" massage. How can we get the phone connected to the GPS? Do I need to switch on GPRS which will need addition data cost. Any Bros can help on this problem? Thanks.. ↡ Advertisement Link to post Share on other sites More sharing options...
Guyver 1st Gear November 17, 2008 Share November 17, 2008 After configuring everything, I stay at the kitchen window .... Managed to get satellite fixed within a few minutes. Link to post Share on other sites More sharing options...
Help1 1st Gear November 17, 2008 Share November 17, 2008 hi, you need to configure the GRS Connection, i used to have that problem when i first try it out, but i forgot liao what is the exact configuration. you can call to asiagis 63914500 for tech support, i did called them up on this issue. Link to post Share on other sites More sharing options...
Kingcopa 1st Gear November 17, 2008 Share November 17, 2008 One of the method is to turn on the advance GPS on ur setting. Once i lock in, i will turn it off. Another metod is like what the bro mention, call up n ask for help. Link to post Share on other sites More sharing options...
Help1 1st Gear November 17, 2008 Share November 17, 2008 got an email from the tech support, Samsung i900 Omnia GPS Settings Go to Start>Setting>System>GPS (or External GPS)>Program>Set to Com 3 Go to Start>Setting>System>GPS (or External GPS)>Hardware>Set to Com 9, 9600 Start NAVFone PPC. When connecting to GPS, set User Define>Com 3, Baud Rate: 9600. Note that GPS is only available outdoors. Please let me know if you have further queries. If you do not wish to wait too long for a valid GPS connection, kindly use the Enhance GPS option. In can be found under Setting>System>Enhance GPS. Kindly enable all the options and tap OK. The next time that GPS is being connected, the GPS data will be downloaded via GPRS. Enhance GPS need not be used all the time, only when reception issues are encountered. Note that normal GPRS charges will be incurred when Enhance GPS is used. Link to post Share on other sites More sharing options...
Kingcopa 1st Gear November 17, 2008 Share November 17, 2008 Thanks alot. I will try it out later when i knock off. Will file report tml. Link to post Share on other sites More sharing options...
Tohto Hypersonic November 17, 2008 Share November 17, 2008 Thanks for all the reply. Finally manage to get it connect. Take a long 15 mins for 1st time. Following connection seems to be faster, in less than 5mins. Link to post Share on other sites More sharing options...
Titanium 4th Gear November 17, 2008 Share November 17, 2008 Try this... It help a bit. http://mysamsungomnia.wordpress.com/2008/1...g-enhanced-gps/ Link to post Share on other sites More sharing options...
Kingcopa 1st Gear November 18, 2008 Share November 18, 2008 If i wanna put some software into my omnia, whr shld i save the file? sound like a stupid qns but need clarification Link to post Share on other sites More sharing options...
Will_I_Am 2nd Gear November 18, 2008 Share November 18, 2008 I finally realise what was the problem. The threaded SMS is the culprit. You see, I have more than 12K SMS and the threaded SMS somehow caused the whole phone to slack like hell. Disabling it solved everything. Now, that's a nice phone So bad meh? Why not you try disabling all the vibration thingy etc .... could improve speed abit. Link to post Share on other sites More sharing options...
Will_I_Am 2nd Gear November 18, 2008 Share November 18, 2008 Depends. Some s/w like the bundled AGIS Nav GPS s/w requires you to install to your external Storage card in order for it to work. Most of the time, you can install it to your internal storage which is 8GB or 16GB. Link to post Share on other sites More sharing options...
Kingcopa 1st Gear November 18, 2008 Share November 18, 2008 Thanks. I will try it out. DL SPB mobile shell program. trying it out tonite Link to post Share on other sites More sharing options...
Help1 1st Gear November 18, 2008 Share November 18, 2008 no worries usually take 10-15min to connect but be warn, the battery power consumption is very high if you start using GPS Link to post Share on other sites More sharing options...
Guyver 1st Gear November 18, 2008 Share November 18, 2008 I finally realise what was the problem. The threaded SMS is the culprit. You see, I have more than 12K SMS and the threaded SMS somehow caused the whole phone to slack like hell. Disabling it solved everything. Now, that's a nice phone Oic ... I've tried the phone before ... so I personally find it not bad. But I got some problems with the contact list ... so I sold it away. Link to post Share on other sites More sharing options...
Kingcopa 1st Gear November 18, 2008 Share November 18, 2008 How do i disable thie threaded sms. Find this threaded smses a pain in the a** Link to post Share on other sites More sharing options...
Will_I_Am 2nd Gear November 18, 2008 Share November 18, 2008 Bro, all you need is the software - SMS Treaker as attached. Note that you have to install Microsoft .NET CF 3.5 first before you can proceed with the above. (Do a search and download from Microsoft website). Have fun! Link to post Share on other sites More sharing options...
Kingcopa 1st Gear November 19, 2008 Share November 19, 2008 I have been trying to put some software into my Omnia but somehow, it always propmt me that the software is not a valid pc mobile software? i am puzzled cos i got these software from my frd who is also using a Window based HP. Link to post Share on other sites More sharing options...
Guyver 1st Gear November 19, 2008 Share November 19, 2008 You seems to be enjoying the Samsung Omnia now ... ↡ Advertisement Link to post Share on other sites More sharing options...
Android Phones
Android Phones
W212 owners, please check-in
Samsung and Huawei crush Apple's smartphone global share
Toyota Corolla AE86 Revival! Initial D Fans COME IN!
