Fluffy Clutched August 10, 2008 Share August 10, 2008 DIY on how to do the LED mod http://forums.fourtitude.com/zerothread?id=3797997 heh heh, itchy liow ! ↡ Advertisement Link to post Share on other sites More sharing options...
Othello Supersonic August 10, 2008 Share August 10, 2008 wah, opening the headlights if not done properly, could cause leakage = condensation .... i dare not touch. wld be diff if i got spares lying around. but its damn nice lor Link to post Share on other sites More sharing options...
Tashi Clutched August 10, 2008 Share August 10, 2008 hi mate VERY nice finished product indeed! However, like bro Othello mentioned, given our humid surroundings, any suggestions to getting rid of the condensation problem? blessings + Link to post Share on other sites More sharing options...
Fluffy Clutched August 11, 2008 Author Share August 11, 2008 i;m thinking of putting the LEDs where the lower side grills (where we don't have the fogs) are like the A6 LEDs. i think too risky to take our headlamp unit out...also dunno how to remove without first removing the bumper Link to post Share on other sites More sharing options...
Silhoutte Clutched August 11, 2008 Share August 11, 2008 Wow it looks good! Link to post Share on other sites More sharing options...
Othello Supersonic August 11, 2008 Share August 11, 2008 ahh....., this is more " acceptable". no risk. count me in if you really wanna go ahead, we hantam together !! sounds like a medium difficulty wiring job. point to ponder - is this considered a foglamp mod ? i'm afraid some overzealous TP will envy it and book us. or some green-eyed idiot will report us to LTA Link to post Share on other sites More sharing options...
Pjere Clutched August 11, 2008 Share August 11, 2008 How much will it cost? Link to post Share on other sites More sharing options...
Funkyjazz Neutral Newbie August 11, 2008 Share August 11, 2008 (edited) Bro, Someone in Vagsg is bringing in the LED headlight. www.vagsg.com/forums/showthread.php?t=13263 Edited August 11, 2008 by Funkyjazz Link to post Share on other sites More sharing options...
Othello Supersonic August 12, 2008 Share August 12, 2008 (edited) Matt , this is what it will be .... [inline superb-s6-tfl-01.jpg] Edited August 12, 2008 by Othello Link to post Share on other sites More sharing options...
Othello Supersonic August 12, 2008 Share August 12, 2008 (edited) FAQs from http://www.oznium.com Can the LED strips be cut or trimmed? Yes! You can easily cut the LED strips. Use a sharp utility knife. The LEDs are wired in groups of 3, so you should cut every 3 LEDs. Note: Some of the shorter lengths can't be cut because of a critical power wire inside. Before you cut, just make sure you won't be cutting a power wire, otherwise your LED strip could be damaged. Can the cut section of the strip be re-used? While it is physically possible, it is not a simple procedure and not worth the effort. For practical purposes, you are better off discarding the cut portion. Once cut, is the strip still waterproof? If you cut it right, it will maintain a degree of "weather resistance". But to make a cut strip fully waterproof again, we recommend you add some silicone sealant to the cut end. What is the best way to mount them? Cable ties, also known as zip ties work for many installations. We also include a surprisingly strong 3M double sided adhesive mounting tape. How should they be mounted in the wheel well? Before removing the wheel, you should hold the strip in a few locations behind the wheel until you find a suitable location. Play around with some different options. We find it works best if they are mounted on or behind suspension components. Do the LED strips require resistors? No. The LED strips do not require any resistors. They are ready to work on any 12 volt power source. Which wire is power and which is ground? The silver wire is 12v +, and the gold wire is 12v - (ground). If you accidentally reverse them, nothing bad will happen. price --> 9.5" White USD$10.49 Edited August 12, 2008 by Othello Link to post Share on other sites More sharing options...
Othello Supersonic August 12, 2008 Share August 12, 2008 (edited) instructions & pics !!!! http://www.superb-combi.de/tuning/s6-tfl/index.htm if its in german, we need koolaba's help to translate .... Edited August 12, 2008 by Othello Link to post Share on other sites More sharing options...
Fortress Clutched August 12, 2008 Share August 12, 2008 nice....Is it legal? Link to post Share on other sites More sharing options...
Tashi Clutched August 12, 2008 Share August 12, 2008 Any chance bro, of engaging the professional hands of a mechanic to get this done? I know the few gurus here would slam my silly head for not DIY, but let's say .... would it be possible? blessings + Link to post Share on other sites More sharing options...
Othello Supersonic August 12, 2008 Share August 12, 2008 of cos ! it wld be an easy job for them, just like how they wld fix up foglights. Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 12, 2008 Share August 12, 2008 For a simple LED fixed to the lower door, they charge something like $30 FOR EACH DOOR. U still want to let them do. I prefer to DIY. Easy & fun & get to learn new stuff even. Anybody thinking of ordering those OZ led's? We can do a group buy & have a DIY installation session. Link to post Share on other sites More sharing options...
Othello Supersonic August 12, 2008 Share August 12, 2008 stay tuned. already enquired from a local supplier abt LED strips ..... Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 12, 2008 Share August 12, 2008 Er...Is it the 1 that was recently bashed in MCF? Link to post Share on other sites More sharing options...
Othello Supersonic August 12, 2008 Share August 12, 2008 erm, I din read about it. This is a commercial business whereby LEDs only small part ..... dun think so lah. can pm me the name ? tks ! ↡ Advertisement Link to post Share on other sites More sharing options...
