V200 Neutral Newbie August 15, 2008 Share August 15, 2008 Hi guys and girls. Anybody faced this problem before? My front left speaker and tweeter will intermittently go soft. Now is all of the time (almost no sound). But when I blast music, it will distort a bit then come back to live! Then after a while, it will die off again. I have a 4 channel amp powering my front and rear speakers. I tried switching from channel 1 and 2 (front) to 3 and 4. The left side still gives problems. Any advice? I usually listen to very low volumns when I am with family. Only turn it up when alone. ↡ Advertisement Link to post Share on other sites More sharing options...
Bellaraphon Neutral Newbie August 15, 2008 Share August 15, 2008 u running active or passive? if passive, most probably the crossover kaput liao. Link to post Share on other sites More sharing options...
V200 Neutral Newbie August 15, 2008 Author Share August 15, 2008 passive leh. cross over kaput? I think I try to swop left and right to see how. Link to post Share on other sites More sharing options...
The_young_once Neutral Newbie August 15, 2008 Share August 15, 2008 probably the crossover problem, you know i have this problem in home audio also, sometimes in my past setup(s), yes, encountered it a few times; i think same as your problem? as in, when soft/background listening volumes, suddenly no output (from one side, be it L or R) then you got to crank it up loud suddenly that 'spoilt' channel will come to life, then you turn the volume down to its previous level--after awhile it suddenly goes off again? my experience with that was: old amplifier, one channel output giving problems already, speaker no problem Link to post Share on other sites More sharing options...
Spinworkx Clutched August 15, 2008 Share August 15, 2008 Definately the crossover since you're on passive... If amp spoil, not only your speaker but your tweeter will also have the same problem. In fact, i myself am having the exact same problem now...i troubleshoot and found out its my amp channel that's spoilt...gonna get it changed next week Link to post Share on other sites More sharing options...
Ivan0507 Neutral Newbie August 16, 2008 Share August 16, 2008 maybe you also can check the speakers wiring in between any re-connected wire or using black pastic tape ,during installation previously.if had .the tape under hot condition will melt and cos the current diffcuit to flow. Link to post Share on other sites More sharing options...
Lksr72 Neutral Newbie August 16, 2008 Share August 16, 2008 y not sent to the shop to check??? Link to post Share on other sites More sharing options...
Lksr72 Neutral Newbie August 16, 2008 Share August 16, 2008 jalan kayu have a shop checking is free,the name ah shan Link to post Share on other sites More sharing options...
Christoph Neutral Newbie August 17, 2008 Share August 17, 2008 there are quite a no possibilities. 1) if u r using stock speakers, mayber (paper) speaker torn, need to change new speakers. 2) cross-over wiring not attached properly or spoilt. 3) amp output to speaker faulty. 4) tuning off Link to post Share on other sites More sharing options...
V200 Neutral Newbie August 18, 2008 Author Share August 18, 2008 probably the crossover problem, you know i have this problem in home audio also, sometimes in my past setup(s), yes, encountered it a few times; i think same as your problem? as in, when soft/background listening volumes, suddenly no output (from one side, be it L or R) then you got to crank it up loud suddenly that 'spoilt' channel will come to life, then you turn the volume down to its previous level--after awhile it suddenly goes off again? my experience with that was: old amplifier, one channel output giving problems already, speaker no problem But I switched from channel 1 and 2 to 3 and 4. Still the same. Don't think it is amp. Will try to switch cross overs. Link to post Share on other sites More sharing options...
V200 Neutral Newbie August 18, 2008 Author Share August 18, 2008 Definately the crossover since you're on passive...If amp spoil, not only your speaker but your tweeter will also have the same problem. In fact, i myself am having the exact same problem now...i troubleshoot and found out its my amp channel that's spoilt...gonna get it changed next week Well, both my speakers, mids and tweeters, have this problems. You replacing your crossovers? Do you think I can use other brands on this one? Don't think can find replacements. MB Quarts. You know where to get? Link to post Share on other sites More sharing options...
V200 Neutral Newbie August 18, 2008 Author Share August 18, 2008 maybe you also can check the speakers wiring in between any re-connected wire or using black pastic tape ,during installation previously.if had .the tape under hot condition will melt and cos the current diffcuit to flow. Er, don't have leh. Link to post Share on other sites More sharing options...
V200 Neutral Newbie August 18, 2008 Author Share August 18, 2008 y not sent to the shop to check??? I tried. They just sprayed contact cleaners and then ask me to monitor! Sian. Within the day, the problem came back. Link to post Share on other sites More sharing options...
V200 Neutral Newbie August 18, 2008 Author Share August 18, 2008 jalan kayu have a shop checking is free,the name ah shan Can give me the shop name? Or is the shop name ah shan? Link to post Share on other sites More sharing options...
Bellaraphon Neutral Newbie August 18, 2008 Share August 18, 2008 huh? now both right and left speakers, mids and tweeters have the problem? earlier you wrote only the left side. Link to post Share on other sites More sharing options...
V200 Neutral Newbie August 18, 2008 Author Share August 18, 2008 there are quite a no possibilities. 1) if u r using stock speakers, mayber (paper) speaker torn, need to change new speakers. nothing wrong with speakers. Using after markets one. 2) cross-over wiring not attached properly or spoilt. This one will check and update. 3) amp output to speaker faulty. Tried but don't think it is so. 4) tuning off Will try 2 first. Link to post Share on other sites More sharing options...
V200 Neutral Newbie August 18, 2008 Author Share August 18, 2008 sorry sorry. I meant both my left mids and tweeters have this problem. sorry for the misunderstanding. Link to post Share on other sites More sharing options...
V200 Neutral Newbie August 24, 2008 Author Share August 24, 2008 Hi hi. Some updates. really weird. I exchanged the input in the cross-overs. Meaning, now my left is playing on my right speaker. Vise versa for left. Both speakers and tweeters ok. Don't know what is going on! ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Iceland : Has anybody driven in Iceland before?
Old WW2 Relic disposals
Anybody know what happened eventually?
Dealer re-sell problem car
