Ryanyusoff 2nd Gear April 17, 2009 Share April 17, 2009 I would gladly appreciate if there are any Swift technical experts could help me in this.My ride is Swift '07 1.3MT. Scenario: Was travelling home as per normal at SLE.approaching Mandai exit,slowed down and dropped gear from 5 to 4.While the clutch is still depressed and slight braking and maneuvering the corner,out of sudden,the engine totally dies off! No power,no lights,no aircon and even worse,power steering is also lost! For a full 3 seconds,i was not in control of the car. Then out of a sudden,everything went back on and the engine restarted by itself!I thank God that my family is safe and nothing happened while i'm taking the corner. The question is,what causes it to happen?Battery is fine(less than 6 mths old),no professional ICE(juz radio HU),normal Pivot (blue) VS with grounding.No hardcore modifications done,only got SIMOTA carbon air filter. Can any bros here help me on this?I heard from a friend that there are Swift owners who experienced the same problem with me.What is the exact problem?I think i need to rectify it ASAP coz i always go up north and don't want anything serious to happen(touch wood!) Many thanks in advance ↡ Advertisement Link to post Share on other sites More sharing options...
Acevin Clutched April 18, 2009 Share April 18, 2009 Bro, Hv u tried posting to swiftclubsg.com aka scs? I'm very sure you can get your reply almost instantly since that forum is for Swift. Link to post Share on other sites More sharing options...
Mcblue Neutral Newbie April 19, 2009 Share April 19, 2009 Halo. me also driving zc11s 1.3 mt jdm model. Engine cut off Happened on 1 time at the traffic junction. the key icon on the dashboard flashing, i suposed that the ecu cannot detect the key fob transponder at that model immobilizer kicked in. Suggest you change you key fob transponder battery. Link to post Share on other sites More sharing options...
Hoppe Clutched June 8, 2009 Share June 8, 2009 maybe it is better if you bring your car for a checkup. Kinda dangerous. Link to post Share on other sites More sharing options...
Luojiahuan Neutral Newbie June 8, 2009 Share June 8, 2009 had the same problem too last year. but only once. was driving from nee soon camp back to yishun. engine suddenly just cuts off while my car is travelling around 80km/h at sembawang road. damn scary. cut off for 1 - 2 sec and suddenly everything comes back. not sure what happened. but till now only once. driving a swift'05 1.5A here. Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 10, 2009 Share June 10, 2009 initially i tot is rpm sensor, but now best is monitor first Link to post Share on other sites More sharing options...
Ryanyusoff 2nd Gear June 10, 2009 Author Share June 10, 2009 wat i believe,is that..as i clutched in during the hard cornering,the engine power loss due to clutch fully engaged makes it die off.and as logically as it sounds,as soon i release the clutch,it 'bites' back and turns back on the engine.. but this is just my 2 cents..i might be wrong though. Link to post Share on other sites More sharing options...
So_nice 6th Gear June 12, 2009 Share June 12, 2009 from my understanding, such things wont happen even if u were to clutch in while the car in motion. if it does, then the engine would haf died everytime we change gears. get it check out at the workshop. Link to post Share on other sites More sharing options...
Dscheng 3rd Gear June 19, 2009 Share June 19, 2009 Better bring to workshop and check. Very dangerous le. Link to post Share on other sites More sharing options...
Ryanyusoff 2nd Gear June 22, 2009 Author Share June 22, 2009 thanks again for the advice..brought it workshop and the mechanic has troubleshoot everything.but no problems found though.but luckily it's just a one-off thing.it nvr happened again. ↡ Advertisement Link to post Share on other sites More sharing options...
Chuck Norris Dies at 86
Sudden death due to cardiac arrest
