Junjie 1st Gear April 22, 2009 Share April 22, 2009 Hi, current with this set of 5x17 and PCD is 114.3. tires profile is 215/45/17, if down size to 16" what will be the right profile to go to? If remain on 17" if I switch to profile 205/50/17, comfort level improve? Any bros can advice, appreciate it. ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear April 22, 2009 Share April 22, 2009 Hi, current with this set of 5x17 and PCD is 114.3. tires profile is 215/45/17, if down size to 16" what will be the right profile to go to? If remain on 17" if I switch to profile 205/50/17, comfort level improve? Any bros can advice, appreciate it. 5x17 ? i hope u mean 5 piece of 17 inch not 17inch by 5 inch rim correct size will be 205/55/16 using 16inch by 6.5inch rim 205 50 will improve comfort at lose of some handling, better than going 16 unless u want better fc Link to post Share on other sites More sharing options...
Junjie 1st Gear April 23, 2009 Author Share April 23, 2009 5x17 ? i hope u mean 5 piece of 17 inch not 17inch by 5 inch rim correct size will be 205/55/16 using 16inch by 6.5inch rim 205 50 will improve comfort at lose of some handling, better than going 16 unless u want better fc Thks bro, ya typo error 5 pcs of 17" Now thinking of either maintain 17" but get a set of lighter rims, current feedback that the stock 215/45/17 tires kind of bumpy on the road, maybe can compensate by changing tires to 205/50/17....but lose of some handling as mentioned but then again mine not performance ride more to pt A to B ride If on FC, then I down to 205/55/16 as recommended Link to post Share on other sites More sharing options...
Tkseah Turbocharged April 23, 2009 Share April 23, 2009 (edited) changing to 205/50/17 would be just as bumpy cos sidewall depth not much diff.. a downsize to 16" rims 215/50/16 or 205/55/16 would be better if u wan better comfort.. Edited April 23, 2009 by Tkseah Link to post Share on other sites More sharing options...
Toalson 1st Gear April 23, 2009 Share April 23, 2009 Bro, wat ride did u changed to that comes with stock 17"? Some TC ride? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear April 23, 2009 Share April 23, 2009 changing to 205/50/17 would be just as bumpy cos sidewall depth not much diff.. a downsize to 16" rims 215/50/16 or 205/55/16 would be better if u wan better comfort.. take a calculator and calculate 50% of 205mm and 45% of 215mm and see if its not much different Link to post Share on other sites More sharing options...
Kyojin 1st Gear April 23, 2009 Share April 23, 2009 http://www.1010tires.com/tiresizecalculator.asp Link to post Share on other sites More sharing options...
Junjie 1st Gear April 23, 2009 Author Share April 23, 2009 take a calculator and calculate 50% of 205mm and 45% of 215mm and see if its not much different if i remain on 17" will change to 205/50/17..... Link to post Share on other sites More sharing options...
Lancer79 Neutral Newbie April 23, 2009 Share April 23, 2009 http://www.carbibles.com/tyre_bible_pg2.html ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone watches MMA?
Anyone watches MMA?
Green fingers anyone?
Anyone try Cathay Pacific before?
New Zealand - anyone?
