Firehawk TZ-100
Nolicense
Just changed to this tyre
195/65R15
Reasonable price
Dry Grip - 7
Wet Grip - 7
Noise - 8
Comfort - 8
So far under 300km so have to run in to see how.
anybody else tried this tyre?
its worse than wide oval
same grade as yokohama a300
very soft sidewall, dun try on cars heavier than 1.2 tonne and corner fast, can feel the whole sidewall giving way
Now that you mention it, I do think the side walls are on the soft side.
Will bear this in mind on taking corners. If they are as bad as yoko a300, then very bad grip.
Steering response is quite responsive, better than Bridgestone G3.
Hi guys ...
Sorry sidetrack abit ....
Recently went tyre-hunting ..... so anyone try GT Radial CHAMPIRO 328 ??
It's classeifed as Ultra High Performance category.
Of course, GT Radial is always associate with taxi (toyota crown) though.
Tks !!
Hi guys ...
Tks !!
Go straight to their top model = the HPX
http://www.tyretest.com/pkw_sommerreifen/g..._hpx/index.html
http://www.tyres4u.com.au/brandselector_do...mg-gt_show.aspx
no idea abt g3, but my fren's set worn out in 20+k with 1.3 tonne car
Mine wore out about there, but mine was a 2nd hand set when I bought it years ago, left 70-80% I guess judging by the threads, comparing to a new set that is. Hope my current RE001 will last past 30k...
Btw my car also weight around there [sweatdrop]
Strange.. my G3 still had lots of tread.. must be 30k on them already. I drive a 1.7 ton car to boot.
the TZ-100 now is still no change in performance. The more I try to listen for the noise, the more I find it just as quiet as GR80.
Already drove past 800km
so far performance about the same, only noise seem not as quiet as b4.
Dry Grip - 7
Wet Grip - 7
Noise - 7
Comfort - 8
steering is still responsive, corners are fine.
My driving style is moderate, corner tends to be faster than other people as I don't slow down into corners and tend to accelerate out. The car is 1.7 tons, and I'm moderate light on the pedal.
I'm satisfied its use as an everyday travel tyre.
