RayTravis Neutral Newbie July 30, 2009 Share July 30, 2009 Hi all.. When i drive.. usually around a few minutes later, the CEL will be switched on. Can it be cause of the exhaust..? Cause my exhaust needs welding.. It is making sounds when i drive.. Or could it be something else? Please advise... ↡ Advertisement Link to post Share on other sites More sharing options...
Watwheels Supersonic July 30, 2009 Share July 30, 2009 The problem lies in you cos you dun want to bring it to a mechanic to check and rectify. Even if you post 10000000001 questions here, ppl can only guess. Good luck. Link to post Share on other sites More sharing options...
RayTravis Neutral Newbie July 30, 2009 Author Share July 30, 2009 (edited) The problem lies in you cos you dun want to bring it to a mechanic to check and rectify. Even if you post 10000000001 questions here, ppl can only guess. Good luck. Im bringing it tomorrow.. I just want to make sure cause am not bringing it to my usual place at JB. no time. scared kana chop/ So i just intend to know more.. i ony 1st gear lei.. :( Edited July 30, 2009 by RayTravis Link to post Share on other sites More sharing options...
Watwheels Supersonic July 30, 2009 Share July 30, 2009 Tmr ask your mechanic and you shall find out. I think you are mistaken. Many of us here are just car users like yourself, not car mechanics. There are lots of possibilities on problems for CEL to be on. And only the mechanic is qualify to find out what's wrong. Dun loose sleep over it. It can be just a minor problem. Link to post Share on other sites More sharing options...
Sunburnsam 2nd Gear July 30, 2009 Share July 30, 2009 find your friendly workshop do a Diagnostic check with the OBDII and get the code to find out more. CEL light can mean many things. With the code it will be much easier to get feedback from fellow bros here. Link to post Share on other sites More sharing options...
RayTravis Neutral Newbie July 30, 2009 Author Share July 30, 2009 find your friendly workshop do a Diagnostic check with the OBDII and get the code to find out more. CEL light can mean many things. With the code it will be much easier to get feedback from fellow bros here. THANks alot . . . !! Oh well, can sleep soundly tonight.. then tomorrw hopefully will find out what is the problem.. Link to post Share on other sites More sharing options...
RayTravis Neutral Newbie July 30, 2009 Author Share July 30, 2009 Tmr ask your mechanic and you shall find out. I think you are mistaken. Many of us here are just car users like yourself, not car mechanics. There are lots of possibilities on problems for CEL to be on. And only the mechanic is qualify to find out what's wrong. Dun loose sleep over it. It can be just a minor problem. Thanks bro.. =) at least it clears some of my fears.. Link to post Share on other sites More sharing options...
Pcslim Neutral Newbie July 30, 2009 Share July 30, 2009 THANks alot . . . !! Oh well, can sleep soundly tonight.. then tomorrw hopefully will find out what is the problem.. And don't forget to share us here on what caused the problem. Link to post Share on other sites More sharing options...
RayTravis Neutral Newbie July 30, 2009 Author Share July 30, 2009 And don't forget to share us here on what caused the problem. Will do.. Hopefully by sat or fri night can share.. :) Link to post Share on other sites More sharing options...
Jamstart 1st Gear July 30, 2009 Share July 30, 2009 Just a check, did you switch your petrol grade to a lower one recently? It happened to my colleague where this lights came about. After switching it back to the grade that he used to use, the lights just went off. Dont ask me why cos it just happened this way. Link to post Share on other sites More sharing options...
Fierydog2002 Neutral Newbie July 30, 2009 Share July 30, 2009 wad ride u drinving Link to post Share on other sites More sharing options...
Lewiss Neutral Newbie July 30, 2009 Share July 30, 2009 May be knock sensor got problem........ ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
KIA K3 Owners check-in!
No More Cheques In Singapore come 2027 Jan and EDP (electronic deferred payment)
