Route Clutched August 18, 2009 Share August 18, 2009 Hi, I just bought Penzoil manual gear oil which is 80W90 GL-5, i just saw my manual and it states that for my car recommanded is 75W85 or 75W90 GL-3/GL4. Can i still use my GL-5 on a GL-4 recommanded car ? My car is just a normal car without any LSD... Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 18, 2009 Share August 18, 2009 Hi, I just bought Penzoil manual gear oil which is 80W90 GL-5, i just saw my manual and it states that for my car recommanded is 75W85 or 75W90 GL-3/GL4. Can i still use my GL-5 on a GL-4 recommanded car ? My car is just a normal car without any LSD... Thanks Nope, usage of normal GL-5 gear oil on a GL-4 spec transmission will cut the transmission life by 1/2 due to the high EP additives(sulfur content). Just go back to the shop and exchange for the correct GL-4 spec oil. Link to post Share on other sites More sharing options...
Tkseah Turbocharged August 18, 2009 Share August 18, 2009 any suitable 75w/85 GL-4 MTF to recommend? user manual says need 2.15 ltr.. Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear August 18, 2009 Share August 18, 2009 How about GL5 on differential? Is it ok? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear August 18, 2009 Share August 18, 2009 redline one is very good. I been getting mine from mx for many years now Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 18, 2009 Share August 18, 2009 How about GL5 on differential? Is it ok? Most differential call for GL-5 spec, so it will be the correct oil. Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 18, 2009 Share August 18, 2009 any suitable 75w/85 GL-4 MTF to recommend? user manual says need 2.15 ltr.. GL-4 Amsoil MTG 75w90 or RL mixture of 50/50 MTL/MT90 would be a good choice. Link to post Share on other sites More sharing options...
Route Clutched August 18, 2009 Author Share August 18, 2009 i called them up again but they're only left with GL-5 and the workshop said no difference.. anybody wants to buy my penzoil gearbox oil ? 3 quarts bought today only... selling $10 per quart plus deliver to your house.. pm me. Link to post Share on other sites More sharing options...
Windchoco 1st Gear August 18, 2009 Share August 18, 2009 Hi, I got a car currently at 10,xxx km... During 10k servicing, the service advisor keep psycho me to change gear oil, even though it is not stated in the car manual that must change at 10k . Eventually i did not change, as i thought i can change outside. Anybody can advise me if its advisable to change the gear oil? Thx... Link to post Share on other sites More sharing options...
Tkseah Turbocharged August 18, 2009 Share August 18, 2009 (edited) user manual says capacity is 2.15 ltr, so must get 3 qts? the extra seems a bit wasteful, or can just replace 2 qts? or anyone wanna share half a qt of Amsoil MTG with me? can arrange to change MTF together.. Edited August 18, 2009 by Tkseah Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 19, 2009 Share August 19, 2009 Hi, I got a car currently at 10,xxx km... During 10k servicing, the service advisor keep psycho me to change gear oil, even though it is not stated in the car manual that must change at 10k . Eventually i did not change, as i thought i can change outside. Anybody can advise me if its advisable to change the gear oil? Thx... It's a good idea to do a one time change, get raid of the run-in metal and fill it up with top quality synthetic. This change would last you at least 60k for severe service or 100k for normal service. Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 19, 2009 Share August 19, 2009 user manual says capacity is 2.15 ltr, so must get 3 qts? the extra seems a bit wasteful, or can just replace 2 qts? or anyone wanna share half a qt of Amsoil MTG with me? can arrange to change MTF together.. Yes, IMO abit wasteful too but it's good fill up full as the gear oil also acts as a coolant for the transmission. Link to post Share on other sites More sharing options...
Octopus 3rd Gear August 19, 2009 Share August 19, 2009 Hi, I got a car currently at 10,xxx km... During 10k servicing, the service advisor keep psycho me to change gear oil, even though it is not stated in the car manual that must change at 10k . Eventually i did not change, as i thought i can change outside. Anybody can advise me if its advisable to change the gear oil? Thx... When I changed by manual transmission oil at 10k km, the looks of the oil was greyish. I guess its assembly grease/oil or factory oil which don't have dye in it... I believe transmission will have some wear metal which should be flush out after run-in. I plan to change again at 50k km. Link to post Share on other sites More sharing options...
Tkseah Turbocharged August 19, 2009 Share August 19, 2009 thanks for info & advice.. actually my user manual says MTF is only inspect every 10k.. did not specify any intervals for replacement.. so my mileage 62k liao MTF still not changed.. but thinking now can change since COE now so high looks like gotta keep my car for another few years.. Link to post Share on other sites More sharing options...
Octopus 3rd Gear August 19, 2009 Share August 19, 2009 Hi, I just bought Penzoil manual gear oil which is 80W90 GL-5, i just saw my manual and it states that for my car recommanded is 75W85 or 75W90 GL-3/GL4. Can i still use my GL-5 on a GL-4 recommanded car ? My car is just a normal car without any LSD... Thanks Better to use the correct specification oil. Not only might GL5 oil attack yellow metal in the gear box, it also do not have the correct fiction modifier which GL4 spec have to enable smooth shifting. I said "might" because I read new GL5 oil have inhibitor to protect against yellow metal attack, but better be on the safer side. Link to post Share on other sites More sharing options...
Windchoco 1st Gear August 19, 2009 Share August 19, 2009 Thanks... ok... so means, change now is better... 1 time change to flush out the run in dirt, and last long long... Link to post Share on other sites More sharing options...
Ixat 1st Gear August 19, 2009 Share August 19, 2009 Bros, I changed my MTF at 60K and only realised the manual states 100K interval. Now its 110K (50K after since last change), should I go for a change? Using RL from MX too... Link to post Share on other sites More sharing options...
Furrynadz 5th Gear August 19, 2009 Share August 19, 2009 Bros, I changed my MTF at 60K and only realised the manual states 100K interval. Now its 110K (50K after since last change), should I go for a change? Using RL from MX too... u already answered your own question ↡ Advertisement Link to post Share on other sites More sharing options...
Where to get Workshop Manual
BMW M Cars Are Done With DCTs, and Soon, Manuals Too
Looking for a manual car because real men use three pedals!
To those driving manual cars
Looking for Subaru Exiga Owner's Manual
This Chinese Electric Car Designed For Driving Schools Has A Fake Manual Transmission
Motul Brake Fluids for the street or the race track?
