Yaloryalor 5th Gear August 23, 2009 Share August 23, 2009 Dear Bros, When I was travelling up north with speed higher than 110km/h; my car will vibrate when I step on the break pedal. My friend told me its the ABS causing the car to vibrate. I do not have this situation when travelling/ breaking locally with speed less than 100km/h. My ride is Accord CL7. My friend driving Legacy does not has this problem at high speed. I would like to check if any of the Bro encounter the same situation or has any advise? Tks! ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear August 23, 2009 Share August 23, 2009 change ur pads and rotors full vehicle alignment full 4 wheel balancing Link to post Share on other sites More sharing options...
Jolie888 Clutched August 23, 2009 Share August 23, 2009 Your brake rotors (not the pads yah) are warped. Need to replace them. Did you spray water onto the hot rotors (e.g. after a long hard drive) recently? Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear August 23, 2009 Author Share August 23, 2009 (edited) Thanks All! I did my rims balancing when I changed to current rims about 5 months ago and did the wheel alignment just 3 months ago. Rotors, I will check with my workshop tomorrow. How do we know its front or rear? Edited August 23, 2009 by Yaloryalor Link to post Share on other sites More sharing options...
Furrynadz 5th Gear August 23, 2009 Share August 23, 2009 if u can feel it means its front ur brake bias is more than 70% front anyway Link to post Share on other sites More sharing options...
Blueray Hypersonic August 23, 2009 Share August 23, 2009 think its the brake discs, probably needs skimming. Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 23, 2009 Share August 23, 2009 go n skim it for $65 inclusive of all taking out n installation .....problem solved Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear August 23, 2009 Author Share August 23, 2009 Bro, you know where to go it @ $65? I dunno how much my usual workshop is charging. Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear August 23, 2009 Author Share August 23, 2009 if u can feel it means its front ur brake bias is more than 70% front anyway Thank you! Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear August 23, 2009 Author Share August 23, 2009 think its the brake discs, probably needs skimming. Dun need to change? Just skimming? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear August 23, 2009 Share August 23, 2009 Dun need to change? Just skimming? read article http://www.aa1car.com/library/2003/bf110322.htm Link to post Share on other sites More sharing options...
Tanly Neutral Newbie August 23, 2009 Share August 23, 2009 ur rotors warped just skim will do,dats wat they do at Kah motor oso.All rotors will warp eventually Dun need to change? Just skimming? Link to post Share on other sites More sharing options...
Blueray Hypersonic August 23, 2009 Share August 23, 2009 Dun need to change? Just skimming? doubt so, had same problem on my previous car. just skimming only. think problem was caused by me washing the car too many times when it was still hot, so water actually warped the discs. Link to post Share on other sites More sharing options...
Queks 2nd Gear August 23, 2009 Share August 23, 2009 No point guess.... Do a quick check at AD or workshop then decide. Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear August 23, 2009 Author Share August 23, 2009 Thanks again! Pls let me know if you have any reliable workshop to recommend for the skimming servicing with reasonable price. ↡ Advertisement Link to post Share on other sites More sharing options...
Budget 2025 - February 2025.
Noise from front engine area (suspension,maybe) when hit bump with left turn
What to do when kena Shingles??
Load noise when car speed >80km/h
Screeching sound when braking
Breaking News: Fire and Explosion at Jalan Buroh 21 Jun 2019
Inconsistent RPM
Inconsistent RPM
Almost reach 3000rpm when travel at constant 100km/h
