Altivo 3rd Gear September 3, 2009 Share September 3, 2009 wat logic is this?? i think what he meant is that with time, air will permeate through the rubber. In that case, fill up with nitrogen. ↡ Advertisement Link to post Share on other sites More sharing options...
Tanshida1201 Neutral Newbie September 3, 2009 Share September 3, 2009 Based on my personal experience, if pump 10-15Kpa more than the recommended gives me better FC. However, ride will be more bumpy. My friend pump more than the recommended pressure and his tire puncture when his car went over a piece of wood. Link to post Share on other sites More sharing options...
Yuan 6th Gear September 6, 2009 Share September 6, 2009 My tyre shop checked and pumped my tires at 32-34 psi with nitrogen. I go to them every fortnight or once a month. In addition, I do my tyre rotation every 20k mileage. Not sure whether this is right or way. My last set of tires were maintained in this way and they manage to last me another 10k more mileage before changing to the current set. Link to post Share on other sites More sharing options...
Yeobh 4th Gear September 6, 2009 Share September 6, 2009 Over inflation should not be more than 10% of the recomended air pressure. Link to post Share on other sites More sharing options...
WTF 4th Gear September 6, 2009 Share September 6, 2009 Saw an article in ST last Sat under Classifieds that recommendation is to rotate tires every 7K-8K. I did mine every 10K during servicing. Lately also find my tires losing air much at a faster rate. After pumping a week ago, pressure has dropped from 210 Kpa to about 185 KPa. Is this normal? How often you guys check and pump your tires? ↡ Advertisement Link to post Share on other sites More sharing options...
Valve stem washer?
Valve stem washer?
HSA recalls 3 brands of high blood pressure drugs
Tyres pressure for 225/45/R17
Do I need to change tire ?
Tire patching types and prices
Spare tire. do u remove or leave in boot?
Continental's New Sustainable Tire Concept Revealed At Munich
