Ken4555 1st Gear January 17, 2010 Share January 17, 2010 hi bros... Sunny N16... any good for changing to a lighten campulley or flywheel? whats the difference actually? Thanks... ↡ Advertisement Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 18, 2010 Author Share January 18, 2010 wats the difference if you do a change on a stock sunny... compared to a maybe done exhaust, air filter, plugs, coil boosters... etc... thanks... Link to post Share on other sites More sharing options...
Nmnhnlm Clutched January 18, 2010 Share January 18, 2010 !!!NEVER TOUCH YOUR CRANK PULLEY!!! If you really want, lighten your flywheel. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear January 18, 2010 Share January 18, 2010 !!!NEVER TOUCH YOUR CRANK PULLEY!!! If you really want, lighten your flywheel. can I know, why not? =p Link to post Share on other sites More sharing options...
Nmnhnlm Clutched January 18, 2010 Share January 18, 2010 can I know, why not? =p Its because of the harmonic dampener. Most cars have their harmonic dampener attached to the crank pulley. IF you remove it, it can cause crankshaft failure. EXTREMELY risky and not advisable for that tiny bit of performance increase. If you want, replace other pulleys like power steering or water pump instead. Link to post Share on other sites More sharing options...
Nmnhnlm Clutched January 18, 2010 Share January 18, 2010 wats the difference if you do a change on a stock sunny... compared to a maybe done exhaust, air filter, plugs, coil boosters... etc... thanks... My advise is to save up the $$$ and drop in Turbo instead. If you want coil boosters, go for CDI ones like MSD, Accel, Crane etc.... Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear January 18, 2010 Share January 18, 2010 Its because of the harmonic dampener. Most cars have their harmonic dampener attached to the crank pulley. IF you remove it, it can cause crankshaft failure. EXTREMELY risky and not advisable for that tiny bit of performance increase. If you want, replace other pulleys like power steering or water pump instead. I kinda heard many people changing to aluminium crank pulley and till date, noone actually complain but keep saying pick-up is much better. But for that kinda price, I think not worth buying it..~ Link to post Share on other sites More sharing options...
Nmnhnlm Clutched January 18, 2010 Share January 18, 2010 I kinda heard many people changing to aluminium crank pulley and till date, noone actually complain but keep saying pick-up is much better. But for that kinda price, I think not worth buying it..~ You will also notice more engine vibration. As for the better pickup..I would say its just slightly better. If really want to change, I would pick on flywheel instead. Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 18, 2010 Author Share January 18, 2010 !!!NEVER TOUCH YOUR CRANK PULLEY!!! If you really want, lighten your flywheel. ok i do agree with you yes... but why u say so? Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 18, 2010 Author Share January 18, 2010 You will also notice more engine vibration. As for the better pickup..I would say its just slightly better. If really want to change, I would pick on flywheel instead. bro... flywheel only makes your RPM ref more freely correct? so not exactly faster... unless hard driving on circuit... as for turbo for sunny?..... in SG $5k will get only basic... yes instant horses but sooooooooooooo many risk of leaks... blown gaskets... lousy tunning... con rods... clutchslip... aiyo i could go on... nothing original on the sunny can take the extra horses... the amount of $ spent on a turbo and then the upgrades on a sunny is not cost effective.. Sunny has no sporty handling watsoever... i took quiet awhile to stiff my sunny up properly... Link to post Share on other sites More sharing options...
SaNibOy Clutched January 19, 2010 Share January 19, 2010 I used a lightweight crank pulley before but sold it off after a few months as i saw the post one of the forummers here tat his lightweight pulley snapped at the centre. Yes, pickup defnitely a bit better but it does not add horsepower. Now, im using a stainless steel under pulley. Same effect except u need to change the beltings cos its smaller in size. Bu at least i can b rest assured stainless steel won't break like tose "aircraft aluminium" ones. Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 19, 2010 Author Share January 19, 2010 I used a lightweight crank pulley before but sold it off after a few months as i saw the post one of the forummers here tat his lightweight pulley snapped at the centre. Yes, pickup defnitely a bit better but it does not add horsepower. Now, im using a stainless steel under pulley. Same effect except u need to change the beltings cos its smaller in size. Bu at least i can b rest assured stainless steel won't break like tose "aircraft aluminium" ones. omg break?????? must be really hard driving?... stainless steel? more for visual shiok? and smaller?? tune again? Link to post Share on other sites More sharing options...
Nmnhnlm Clutched January 19, 2010 Share January 19, 2010 Hi Bro. I don't meant to sound offending but I seriously don't think you should spend $$$ to improve your car's performance. The reason is that the Sunny is not designed for high performance and its going to cost you alot to improve the performance. Thus no point. Link to post Share on other sites More sharing options...
SaNibOy Clutched January 19, 2010 Share January 19, 2010 omg break?????? must be really hard driving?... stainless steel? more for visual shiok? and smaller?? tune again? Nope. He went for a trip up north. Imagine his lightweight crank pulley give way in the middle of the journey? Scary rite? Y not just go for light mods; free up ur exos flow. At least worth the money spent. Link to post Share on other sites More sharing options...
Nmnhnlm Clutched January 19, 2010 Share January 19, 2010 Nope. He went for a trip up north. Imagine his lightweight crank pulley give way in the middle of the journey? Scary rite? Y not just go for light mods; free up ur exos flow. At least worth the money spent. This should serve as a good warning for those who intend to change their crank pulleys. Most of these aftermarket products do not go thru adequate testing before they are put on sale. Link to post Share on other sites More sharing options...
SaNibOy Clutched January 19, 2010 Share January 19, 2010 No use also. Marketing tactics nowadays r so influential tat buyers just ignore warnings given from ppl who had tried and tested the products. They would stil splurge their money on useless mods anyway. Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear January 19, 2010 Share January 19, 2010 easiest and safest mods(in terms of not screwing up your engine) are operating your CAT, changing to free flow muffler, changing to free flow intake, lighten/downsize rims and lighten your car. if you have to do more than that to get the performance you require, then i would rather change car. thats my take. Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 20, 2010 Author Share January 20, 2010 (edited) Hi Bro. I don't meant to sound offending but I seriously don't think you should spend $$$ to improve your car's performance. The reason is that the Sunny is not designed for high performance and its going to cost you alot to improve the performance. Thus no point. yes do agree.. but am not looking at making it comparable to rexes and evos... but a century sprint of like 8-9 seconds would be great.. that is ofcourse WITHOUT touching the gear box and tyre sizes.. so as to maintain comfortable cruising speeds.. so far only the old school v-tecs can provide these kinda set-ups.... normal driving ok shiok... full blast also shiok... Edited January 20, 2010 by Ken4555 ↡ Advertisement Link to post Share on other sites More sharing options...
Must resurface the flywheel when changing the clucth??
156 Lightened Flywheel
Lighten Crank Pulley
Lighten flywheel
Lighten flywheel
Small Upgrade - Flywheel
Clutch change and flywheel.
3.8kg Flywheel
3.8kg Flywheel
